  • The Bluetooth Stereo Amplifier adopts performance 2pcs texas instrument TPA3116D2 amp chip, dual-channel max output power 50W x2 +100W to get clear audio sound, no pop, no audible noise, dead silent when nothing is playing through it;
  • Speakers full frequency output, By using the custom treble bass knob and adjustable 40-300Hz cutoff frequency for the subwoofer, you'll be able to get the best sound;
  • Supports wireless playback from Bluetooth devices, Bluetooth 5.0 wireless music streaming technology with external antenna make a transmission distance of more than 15m/49ft;
  • Full metallic shell to ensure high quality and durable, advanced circuitry design, built-in speakers protection circuit to ensure Hi-Fi clear and clean sound; With unrivaled sound for the customers who pursue HiFi sound;
  • Upgraded DC power outlet for safe use without sparks, included high quality 24V/4.5A power supply (The plug of the power adapter will match the country of your delivery address) enough to drive most passive speakers and powered/passive subwoofer.
BT30D Bluetooth 5.0 2.1 Channel Power Amplifier with Bass and Treble Control
Detailed description
Model BT30D
Chippest TPA3116D2
Maxpower Output 50W*2+100W
THD 0.05%(@1W)
SNR ≥98dB
Working Voltage 12-24V
Speakers Frequency Response 20Hz-20kHz(±3dB)m
Bass Cutoff Frequency Range Adjustment 20-200Hz
Impedance 2-8 Ohms
Device Dimension L118 x W132 x H35 mm/4.72 x 5.2 x 1.38inch
Input mode Bluetooth/RCA
Output mode Passive Speakers + Passive/Active Subwoofer
Bluetooth Bluetooth 5.0, up to 15m/49ft wireless range without hindrance
Wireless Range Up to 15m/49ft
Fosi Audio BT30D Amplifier 1
24V 4.5A Power Supply 1
User’s Manual 1
Video
Compare with similar items
Based on 24 reviews
75%
(18)
8%
4%
13%
Watt Phuket
Great sound
t
tommaso alabiso
Well done guys sturdy and powerful only thing I would add some frequencies on the panel for the sub freq selector I know it’s small but would help
Nicholas Studebaker
Fosi BT 30D. (Not the pro)
There is a lot to like about this powerhouse amp. Actually everything, with the exception of an unsatisfactory explanation of how the frequency knob functions, namely, there are no units of measurement marked around the knob (example: 30 Hz, 50 Hz, 70 Hz) to know where the crossover is being set. Over all great amp.
John Panicker
Ordered BT 30 but not received yet
Ordered before more than 20 days. But still not received. Fosi have no accurate system of tracking the shipment. When track as per the information from the chat window, the shipping companiy’s status display the status of more than one one week before. When try to contact whith the team through “talk to human” it doesn’t connect to a human rather than showing the message not to leave the chat as they are online. I didn’t get any reply through email recently. Anyway I am going to wait some more days. After that I shall decide the next step
Lior Friedman
I'm very pleased. Works perfect
