Fosi Audio DA-2120D Amplifier is a Bluetooth 5.0 audio amplifier for passive speakers that features a stereo 100 watt x2 power output. Can provide you with high-fidelity streaming music.
DA-2120D is a 2.1 channel power DAC amplifier that is equipped with Bluetooth, PC-USB, coaxial, optical, and 3.5mm aux input. Remote control to switch volume, bass, and modes.
Up to 50ft, Bluetooth transmission distance & 20ft remote control distance: Super long Bluetooth transmission distance and remote control distance ensures you connect and control audio devices from a distance at home.
Specifications | Details |
Model | DA2120D |
Output Power | 100W + 100W @4Ω |
Terminating Impedance | 4-8Ω |
Input Mode | Bluetooth + 3.5mm AUX + PC-USB + Optical + Coaxial |
Output Mode | Passive speakers + Active speaker + Active subwoofer + Headphone output |
Frequency Range | 15Hz - 20kHz |
PC-USB Input Sampling Frequency | 24Bit/192kHz |
Optical/Coaxial Input Sampling Frequency | 24Bit/192kHz |
THD | ≤ 0.001% |
SNR | ≥ 90dB |
System Supported | XP/W7/W8/W10/MAC/Linux |
Bluetooth | 5.0 |
Bluetooth Name | Fosi Audio DA2120D |
Bluetooth Transmission Distance | Up to 50ft |
Remote Control Distance | Up to 20ft |
Device Dimension | 4.72*5.31*1.37inch |
Working Voltage | 12V - 24V |
Power Supply | 24V 4.5A |
Item | Quantity |
DA2120D Amplifier | x 1 |
DC 24V Power Supply | x 1 |
Remote Control | x 1 |
Bluetooth Antenna | x 1 |
Optical Cable | x 1 |
PC-USB Cable | x 1 |
3.5mm to RCA Cable | x 1 |
User’s Manual | x 1 |
Compare with Similar Items:
DA2120C+32V Bluetooth Amplifier 2.1CH 120W x2
