  • Input: BT/RCA/OPT/USB/COA; Output: Passive Speakers/Subwoofer/Pre-Out
  • Amp Chip: TPA3255×2; THD: ≤0.03%; SNR: ≥100dB
  • Max Output Power: 165W×2+350W@4Ω
Multiple Outputs
Supports outputs for Passive Speakers, Subwoofer, and a Pre-out, enabling flexible setups for both stereo and 2.1 systems.
Automatic Standby Feature
Automatically enters standby mode after 2 minutes of no signal input, effectively reducing energy consumption and extending device lifespan.
Quick Mode Switching
Easily switch input modes with one click, and settings automatically restore to the previous upon restart, eliminating repetitive adjustments.
Dual 4700μF Capacitors
Features high-quality large-capacity capacitors that enhance sound quality, dynamic range, and stability, extending the amplifier's lifespan.
  • All-in-One DAC Amplifier: The MC351 integrated amp features high-resolution decoding capabilities, supporting Bluetooth, USB, Optical, and Coaxial digital inputs. With its extensive input and output options, you can easily set up a 2.1 home theater or other stereo HiFi audio systems.
  • High Power with Great Sound: Equipped with two high-end Texas Instruments TPA3255 Class-D amplifier chips and a 100-fin heatsink, the MC351 can stably output up to 165W x 2 + 350W power in a 2.1 channel setup. The dual PCBA separated design ensures that the input and output signals do not interfere with each other, providing you with the purest and most impeccable sound quality.
  • User-Friendly Control Design: Supports one-touch switching between 5 input modes and includes bass and treble controls, with central detents for tone defeating, for easy sound customization. It also features an automatic standby function, entering standby mode after 2 minutes of no signal input to effectively reduce power consumption.
  • Vintage Charm: The eye candy round mini VU meter adds a classic retro vibe to your sound system. The needle of the level meter will dance to the music, providing you with both visual and auditory enjoyment. The MC351 is an excellent companion for turntables, allowing you to relive classic tracks.
  • Exquisite Craftsmanship: Featuring an all-aluminum-alloy CNC integrated design and a finely sandblasted metal finish, the MC351 boasts a seamless body with no visible screws, showcasing minimalist aesthetics. The all-metal body ensures durability, and you can enjoy the peace of mind provided by Fosi Audio's 24-month warranty.
  • Output Power:
    165W x 2 + 350W @ 4Ω
  • Terminating Impedance: 4-8Ω
  • Input Mode: Bluetooth 5.3+RCA+COA+OPT+USB
  • Output Mode: SPK OUT+SUB OUT+3.5mm PRE OUT
  • THD: ≤0.03%
  • SNR: ≥100dB
  • Device Dimension: 7.28  x 5.0 x 2.24 inches
  • Sampling Rate: USB24bit/96kHz ; OPT/COA 32bit/192kHz
  • MC351 Power Amplifier x 1
  • 32V/5A Power Adapter x 1
  • User’s Manual x 1
Customers praised the "great sound quality," compact design, and "plenty of power." The sleek appearance and Bluetooth connectivity are highlights. Some shoppers noted concerns about power output requiring higher volumes, heating issues, and lack of remote control. Build quality is "excellent" though some experienced technical issues.
  • 5 stars: 21 (66%)
  • 4 stars: 7 (22%)
  • 3 stars: 2 (6%)
  • 1 star: 2 (6%)
DocHouse (Germany)
Great amp
No better amp beside my mac
Alberto (Mexico)
Excelente amplificador
Corrijo me calificacion, el amplificador de es de excelente calidad,
la cadena de sonido fue Amplificador Fosi MC351 -- Bocinas de torre Polk Es55, Bluetooth -- Spotify (Via Celular Ipod, mi celular samsung no funciono bien con los 2 canales en el Lef sonaba muy bajito pero era un tema del celular) ya lo cambie y suena bien, excelente amplificador! y de favor si peuden borrar mi calificacion anterior ya que era una falla del celular y no del amplificador.
Alberto (Mexico)
Fosi Audio MC351
Soy nuevo en esto del audio, compre mis bocinas Polk ES55 y compre es amplificador, las bocinas suenan regular una bocina, la del lado izquierdo no suena casi nada, la del lado derecho suena bien pero no me suenan con sonidos brillantes, nitidos ni equilibrados como en la sala de audio en que las escuche, no se si la potencia del amplificador es poca a la que necesitan los altavoces de torre, o igual que aflojen en unos meses las bocinas o bien no se usar el equipo amplificado Fosi! pero me parece buen amplificado ya pondre otras bocinas perod e estanteria technics que estaban arrumbadas. ya hi les dire como suena el amplificador y esas bocinas
s
shiva (India)
I am using this product since last few days with so many input options like, bluetooth, Co axial, USB and RCA. I have not tried Optical input yet. Today I used USB with MAC and Apple Hi resolution lossless music using MIDI. Also with 48 V power supply. Sound quality is excellent. But there is some heating issues in Amplifier. I think its design should be improved like ZA3.
s
shiva (India)
Today, I received this amplifier directly from Fosi Audio after 12 days of eagerly waiting for it. I am using it right now and posting my feedback as well. The sound quality is good. Presently, I am listening to sound on my two old bookshelf speakers from SONY. I have not attached a subwoofer yet, but the sound quality is still excellent. The Bluetooth functionality is working fine.
Fosi Audio products are good for specific uses at a low cost. The build quality is robust, and I think it will be a reliable companion for a long time. I am already having ZA3 balanced amplifier by Fosi Audio. I have purchased it to listen Audio CDs by connecting it with coaxial cable from output of Sony Blue ray Player. Also my old Passive Subwoofer of 180 watt can be connected. This will be complete 2.1 setup for stereo listening. I found this product very useful when you do not want a big setup and still want to listen quality sound. I wish Fosi Audio would also come up with other products like a CD player and a turntable. . Best wishes to Fosi Audio and thanks for making such good products.
d
darren (Australia)
awesome sound
super clean amp,and simple setup.
Jijo (Kuwait)
Good Product
Its very good and easy to use and best looking amplifier for 2.1 channel, Worth for its price and i have made a video abou it in my channel https://youtu.be/gUDzU0fuTOA?si=H4pSx4TWx7CGaYc5
Juan (Argentina)
Magia pura!!
Excelente producto, muy buena calidad de terminación, buena potencia. Realmente muy satisfecho por la compra.
j
john (United States)
MC351 2.1
No problem. Loaded with power. Running jbl 46710k,s connects Bluetooth fine. Is a great Bluetooth amp. I recommend for the right application
William (United States)
Exactly what you expect
The device is exactly what you see online and fits the description. I will add that the design looks very nice on my bookshelf.
A (Canada)
See what you value
Good but I feel like it was a bit expensive for what it provides.
Garin (United States)
Pretty decent
It's a little under powered compared to its published rating, but overall I'm reasonably pleased.
Sleek looking device. Bluetooth works well. Have yet to experiment with the DAC but looking forward to it.
Farzad (United States)
Everything is good just have big problem , this amp don’t have a remote control for volume
M (Germany)
Disappointing Power House
After lots of back and forth and not getting a replacement unit, the Fosi support sent me a file to patch my MC351 that was supposed to fix the imbalance issues I experienced with the amp and my software (MacOS). I had to get a windows machine first because their patching software is Windows-only.
Anyway, the firmware patch fixed the imbalance issues afaik (so far) but the VU meter is still not working and the sound is sharper now, which is a bit weird.
Overall a very powerful speaker amp (48V option) in a tiny package with a bit of a questionable service. I’m hoping they can fix all factory units for future reference and that the amp actually lasts as long as it should.
For now it’s a 50/50 recommendation
Alberto (United States)
Smooth, awesome power
Night and day difference with my older less powerful amp I replaced. Sonic quality is simply amazingly better
JC (United States)
Great little amp
The Fosi MC351 is a great little amplifier. It looks awesome and it has plenty of power for normal listening. The overall build quality is impressive
Amit (United Arab Emirates)
Fosi Audio MC351 2.1 Review
Build quality - Excellent
Look and Feel - Excellent
Power to Drive speakers ( in my case KEF Q150) --> The volume button is turned up to almost 80% then you kinda get some punch out of the speakers. Basically it lacks clean power to push these bookshelve speakers of mine. Thats my observation.
Byron
Great
Naman (India)
Beauty & the Beast
A beastly machine in a spectacularly compact size.
Arjun (United States)
Good sound, just missing a crossover filter on the speaker output
Good sound, just missing a crossover filter on the speaker output. But otherwise, no concerns.
Antonio (United States)
The volume is really low and the UV meter hardly moves.
I have only tried it with the Bluetooth and i only plan to use the bluetooth I made sure the volume on the Bluetooth device was all the way up
Jose (United States)
Keep up the excellent designs !
Excellent piece of equipment with great performance.
a
ahmed (Kuwait)
Didn’t receive my item untill now i will give it zero star
Craig (United States)
Fosi Audio MC351
Wow, this is a nice little unit. I've seen a lot of praises for the ZA3 and this unit with the Bluetooth was a pleasant surprise. Great sound quality and a nice touch with the meter. You have to rock it a bit to get it to move, but that's OK. Very cool and versatile.
P.B. (Greece)
As expected
Jim (United States)
Great amp
The amp is a great little workhorse
Wonderful build and great sound
I did have to burn in a bit, at first I thought it dud not have the power I needed, but it soon started to sound better and better.
It also arrived much sooner than I had expected
