S3 Lite Streamer
Bring Your Old Stereo into the Modern Age
Pure Digital Transport with USB Output
A Perfect Digital Bridge to Your External DAC
The S3 Lite brings modern streaming to both classic and modern HiFi systems, offering a simple, stable connection and high-fidelity digital audio that complements your existing hardware. Enjoy seamless playback with no audible pops, and relay noise when changing tracks and switching streaming quality.
Unlock Up to 768kHz Lossless Audio
Its built-in USB-A output supports lossless audio up to PCM 32bit/768 kHz, delivering a detailed, transparent signal that allows your downstream DAC and amplifier to define the system’s final character.
Seamlessly Integrates into Your Existing Stereo System
Comprehensive Digital Outputs
USB-A, optical, and coaxial outputs ensure excellent synergy with virtually any DAC. With digital-output THD+N as low as 0.000003%, the S3 Lite delivers a clean, faithful audio source.
Stream Your Favorites
You can stream music directly from your music Apps to the S3 Lite for seamless playback.  Capable of up to PCM 32bit/768kHz lossless audio, it delivers wired-grade sound quality with the convenience of wireless control.
All-New App Super Easy Setup
The S3 Lite is easy to set up and control through the Fosi Audio app. The app’s clean, intuitive interface allows you to manage playback, switch sources and output modes, and fine-tune your sound with a built-in 10-band precision EQ.
Seamless Wireless Streaming
Dual-band 2.4 GHz/5 GHz Wi-Fi 6 delivers stable coverage of up to 100 meters, making setup smooth and quick while enabling seamless control across rooms.
Play Music Everywhere
The S3 Lite supports multi-room synchronized playback via Google Cast and AirPlay 2. With multiple S3 Lite or S3 units placed in different rooms, you can easily control them from your phone and have all speakers play the same music simultaneously, letting your music follow you wherever you go
Compact Footprint
The S3 Lite takes up minimal space and fits effortlessly on a desk, shelf, or inside your HiFi rack. Its clean, minimalist design blends naturally into any audio setup.
Power Sync
The 12V Trigger enables synchronized power on/off with a downstream DAC, automating system control for seamless operation.
Bluetooth Remote Control
Enjoy effortless control of input selection, playback, and power from up to 15 meters away —all without leaving your seat.
Panel Overview
Pure Digital Transport & HiFi Audio Streamer
Dedicated Digital Bridge for External DACs
The Fosi Audio S3 Lite is designed as a pure digital transport to stream pristine, uncompressed audio directly to your high-end external DAC. Featuring USB, Optical, and Coaxial outputs, this HiFi music audio streamer delivers a clean digital signal to your home stereo setup with zero added noise or signal degradation.
Next-Gen Wireless Streaming: Dual-Band Wi-Fi 6 & Bluetooth 5.3
Ultra-Stable, Lag-Free Wireless Connectivity
Upgrade your sound system with high-speed dual-band 2.4GHz/5GHz Wi-Fi 6 and Bluetooth 5.3 connectivity. Experience uninterrupted, high-resolution wireless streaming across your home network whether playing local audio files or online music platforms.
Ultra-High Resolution Audio Transmit (Up to PCM 768kHz)
Precision engineered for audiophiles, the USB output supports lossless PCM audio up to 768kHz with an ultra-low harmonic distortion rate of THD+N ≤0.000003%.
Enjoy hyper-detailed sound quality, remarkable dynamic range, and ultra-transparent acoustic clarity.
Seamless Ecosystem: AirPlay 2, Google Cast, Spotify & TIDAL Connect
Multi-Room Audio & Universal Streaming Support
Stream directly from your favorite platforms with full native support for AirPlay 2, Google Cast, Spotify Connect, TIDAL Connect, Roon Ready(Certification In Progress), DLNA, and Qobuz. Effortlessly integrate the S3 Lite into your smart home network and control multi-room playback directly from your smartphone or PC.
Advanced Sound Personalization: 10-Band Custom EQ
Tailor Your Sound to Fit Any Room or Speakers
Take full control of your listening experience using the integrated 10-band EQ parameter controls. Precisely tune frequency responses to match your room acoustics, headphones, or power amplifier for customized sound signatures.
Compact Design & Smart Control
Compact 5.79-inch (147 mm) chassis fits easily on a desk, shelf, or HiFi rack. Bluetooth remote control works up to 15 m. The built-in 12V Trigger synchronizes power with your external DAC.
  • S3 Lite
  • DC Power Adapter
  • Optical Cable
  • Bluetooth Remote
Can the S3 Lite play audio by itself?
No. It is a pure‑digital transport and requires an external DAC. Removing the onboard DAC brings lower costs and cleaner digital‑signal output.
What protocols are supported?
8 major mainstream protocols: Google Cast, AirPlay 2, DLNA, Spotify Connect, Roon Ready(Certification In Progress), TIDAL Connect, Qobuz Connect and Bluetooth.
How can I pair it with other Fosi products?
It features the unified matte‑black family‑style design. Connect it to a DAC (such as the ZD3) via USB, optical or coaxial cable.
What is the 12V Trigger for?
The 3.5 mm jack outputs a 12 V trigger signal to power‑cycle your DAC or amplifier in sync with this unit.
Customers praised the streamer's "exceptional sound quality" and bit-perfect digital transport. Recent firmware updates greatly improved stability and app responsiveness. Most appreciated the compact design, easy setup, and versatile outputs (USB, optical, coaxial). However, some noted missing Roon certification, software bugs, and basic power supply as drawbacks.
  • 5 stars: 17 (61%)
  • 4 stars: 7 (25%)
  • 2 stars: 2 (7%)
  • 1 star: 2 (7%)
Jaime (Mexico)
Muy recomendable, una sorpresa con el ecualizador de 10 bandas
Muy recomendable, una sorpresa con el ecualizador de 10 bandas, hace que Spotify ahora si suene bien, Spotify debería promocionar estos equipos que mejoran mucho como se escucha
i
iftach (Israel)
NO roon ready certificate
The device is useless and I am very disappointed :(
If I have known it does not work with roon I would have chosen a different streamer.
Yankele (Ecuador)
A winner!
I was looking around for a streamer to set up on my living room and poolside system, and this little piece just released! since i already had a ZD3 it was a match made in heaven! Works great, easy to setup, got one small update {user executed} and i was ready to use it after couple minutes out of the box. Is about 1.5x wider than my fosi stack so it will be on the side for now!
Nosferatrom (Mexico)
Simple, Clean and Excellent
I've been very impressed with the Fosi Audio S3 Lite. It is a simple but highly capable digital streamer, especially if you already own a quality external DAC. Streaming is stable, the digital output is clean, and having USB, optical and coaxial outputs makes it extremely versatile.
The compact design and wide streaming support are also big pluses. For the price, the S3 Lite is one of the easiest ways to add modern streaming capabilities to an existing Hi-Fi system without compromising the digital signal.
Crank (Canada)
Digital Underdog
Picked up the S3 Lite digital transport for a few reasons. I'd been using a Bluesound Node N130 (2021) for the last 5 years, and elected to upgrade the power supply to a PD Creative LPS. The Node is very good and offers more features than the S3 Lite. However, the sound was always in question. It's not incredibly exciting unfortunately. Very practical, and offers a wide range of streaming services. Just looking for a change, the S3 Lite was immediately accessible due to its price point. And, I was only looking for a digital transport since I'm using a Denafrips Iris 15th DDC and Ares 12th-1 dac. Quite literally, I was up and running within 10 minutes. For some, the limited access to only 3 of the current popular streaming services including Spotify, Tidal and Qobuz may be turn-off, but I'm only using those so personally, I'm covered. Burn in is another contentious issue, and it took at least 48 hours before the S3 Lite started to bloom...in a good way. Running bit-perfect streams, the sound is very natural, if not a touch forward. I won't say that it "blows the Node out of the water," as that would not be a fair assessment of either device. However, the S3 Lite is simple to use, without any bloatware, and its performance belies it's price exponentially. The reason it earned 4 stars and not 5 is not a reflection of performance. Rather, it a subjective wish for just a few more options with respect to the number of streaming services on offer. Otherwise, this device is a no risk, no brainer purchase. Stop reading and order the S3 Lite....now!
Soumyajit (India)
Excellent low cost device
Performs way better than its price point.
Timothy (United States)
S3 Lite.
I have 2 of these now. I am very happy with the performance.
Cees
prima
Jaime
muy buen producto, excelente presentación, responde muy rápido y si problemas de conexión
Cesar
Poor WiFi connection and an app that needs improvement. Unfortunately, I cannot recommend this product.
Fosi Lite S3
The set up directions are very confusing, and I can get the set up to the point where it tells me it is connected, But no music plays!! I tried Spotify and cannot get it to play! Yes. it is hooked up to a very good DAC and then to my $6000 Audio research preamp all properly set up, but nothing! By the way I worked for Motorola for years as an Eng, Tech. Needless to say I am very unhappy with this purchase and believe it is probably defective.
Harj (United Kingdom)
Firmware & App Software update Now Refined Streamer.
Fosi S3 Lite Review: Firmware Updates Turned This Streamer Around
When the Fosi S3 Lite first hit the market, it showed plenty of potential on paper as a dedicated digital bridge and transport. However, like many early-stage network audio devices, early iterations were held back by minor software hiccups and playback stability quirks.
After applying the latest firmware and software updates, the S3 Lite feels like a completely matured product.
Key Improvements & Performance
* Rock-Solid Stability: The recent firmware update directly targets signal stability and companion app responsiveness. Stream drops, output switching hiccups, and network latency issues have been completely ironed out.
* Clean Digital Transport: Operating purely as a digital streamer feeding an external DAC, it delivers bit-perfect output over USB, Optical, and Coaxial without adding noise or unwanted coloration.
* App Optimization: The software ecosystem is finally catching up to the hardware. System navigation is smoother, connection management is instant, and setting output parameters is hassle-free.
The Power Supply Compromise
If there is one area where Fosi left room for improvement, it is the included power supply.
While the standard DC wall adapter gets the job done, a linear power supply would have been a very welcome inclusion for a dedicated hi-fi transport. To put this in perspective:
> Comparison: For just $99 USD, Schiit Audio supplies a 100% linear power supply with their Schiit Buf tube buffer—a wall-transformer supply so substantial that it literally weighs more than the main unit itself!
Seeing a budget-conscious audio maker like Schiit bundle a heavy linear power supply at a sub-$100 price point highlights where Fosi could improve in future iterations or offer as an official upgrade path.
Verdict: A Keeper
Initially, early software bugs might have made this unit a candidate for a quick return. However, with the added system stability, seamless daily playback, and reliable digital transport performance from the latest updates, I will definitely be keeping and not returning the Fosi S3 Lite.
It has earned its permanent spot in the digital chain.
Anonymous (Norway)
S3 Lite streamer
A great small streamer, simple to use, good value for the money paid for it.
Absolutely recomeded in a smaller setup.
Steven (United States)
Roon Promise Remains Broken - Edited for Positive Support Response
Original "This review would be a 5 star one if the promised Roon Certification was live. It was promised on all of the advertising and I am very disappointed. Other than that this has to be one of the best streamers out there at even double or triple the price. Please fix this situation!"
Update: Fosi reached out and let me know that they were very sorry that Roon Certification hadn't been completed but that they were working hard with Roon to get it done and they offered a discount for my trouble and I appreciated it.
I really love this thing and am actively using it to Stream Lossless from Qobuz and Spotify and am looking forward to seeing the Roon implementation.
Sathya (India)
Beautiful
Excellent product and th team is simply superb
Jean-Pierre (Switzerland)
Es klingt!
Das Gerät macht ohne einen DAC keine Musik. Somit ist eine Klangbewertung nicht möglich. Die ganze Welt weiss was „Tidal Connect“ ist, nur ich nicht! Lange habe ich für die Einrichtung gebraucht bis ich verstanden habe was „Tidal Connect“ ist. Jetzt macht es Musik und zwar recht gut.
Viktor (Canada)
Fosi audio S3 lite streamer.
Thanks to Fosi Audio for the Lite Streamer! It works really well, and the sound quality is amazing. For this price, I don’t think you can find anything better. I’ve had a few issues with the UPnP folder navigation, but I hope these will be fixed in a future update.
Ilan (Israel)
Still needs Roon certification to be completed
Airplay 2 is no substitute for Roon RAAT.
Anonymous (United Kingdom)
Nice Hopefully the software will improve
Review: Fosi Audio S3 Lite — Stellar Sound Ruined by Buggy Software and Cheap Power
Rating: ⭐⭐⭐☆☆ (3/5)
The Bottom Line: Priced at $199.99, the Fosi Audio S3 Lite delivers phenomenal bit-perfect audio hardware that is severely held back by a highly frustrating software ecosystem and an underwhelming power supply.
The Good: Pristine Sound Quality
When it works, the sound quality of this digital transport is absolutely superb. Feeding a bit-perfect high-resolution stream to an external DAC yields a completely transparent, jitter-free audio profile. The sonic background is pitch-black, dynamic ranges are wide open, and the music feels entirely uncompressed. As a pure digital bridge, the hardware handles audio beautifully.
The Bad: A Highly Unsatisfactory, Buggy App
Unfortunately, getting to that great music is a painful experience. The Fosi companion app is incredibly unstable and buggy. It suffers from frequent connectivity drops, pairing glitches, and frozen screens. Streaming connections stutter regularly, making everyday navigation a deeply unsatisfactory chore. For a device that lacks physical playback controls and relies almost entirely on software, these bugs ruin the user experience.
The Ugly: No Linear PSU (While Schiit Manages It for $99)
The choice of power supply is a massive disappointment. Fosi packs in a generic, lightweight switch-mode wall adapter. It begs the question: why can Fosi not include a proper linear power supply at $200?
By comparison, Schiit Audio includes a robust, heavy linear power supply with the $99 Schiit Buf tube buffer. The external linear transformer on that $99 device actually weighs more than the entire Schiit tube buffer itself. If Schiit can manage a heavy-iron, clean linear power supply at half the price, Fosi has no excuse for cutting corners with a cheap wall-wart on a $200 audiophile streamer.
Pros & Cons
• 👍 Pros: Exceptional, transparent sound fidelity over digital outputs; sleek metal chassis.
• 👎 Cons: App is highly unstable, buggy, and frustrating; cheap switch-mode power adapter instead of a linear PSU.
Anonymous (New Zealand)
Sound
Sound very good
Ashley (Australia)
Exactly what I needed for my system
This has replaced all of the custom raspberry pi based streamers, and works perfectly with my Music Assistant and streaming from my iPhone.
Works perfectly. No lag. Instant music for me.
SAJITH (India)
Wonderful journey started with FOSI AUDIO …
Hi
Wonderful journey started with FOSI AUDIO …..it’s a fantastic streamer with extreme low noise ….. software with no glitches …. Super easy to use …. My chain is S3 lite , my R2R DAC , fosi ZP3 pre amp and my MARANTZ power amp with B&W 603 S3 ….its wonderful to hear the unheared ….
Expecting R2R DAC’s and more musical gears ….
Thank you FOSI TEAM
James (United States)
Not what I thought
First this unit is not very friendly with its user interface.
It's confusing to the point I gave up using it.
Yeah it worked but you still have to use your phone for your streaming source so what's the point?
That was another reason I stopped using this streamer and went to use my old iPhone 8 Plus as my streaming source, it's about the same thing as this streamer being sold here, and still have full use of my regular phone for everyday use while the 8 Plus does the streaming.
Money wasted for me and now it sits in the closet.
Every other Fosi device I have bought has been worth every penny and 10 star rating.
This streamer was a waste.
Jørgen (Norway)
Nice little thing
No issues, no problems.
