Born for HiFi Enthusiasts
  • Max Power Output: 300Wx2@4Ω
  • SINAD: 88dB | SNR: ≥110dB
Bookshelf Scene
Home Theater
Desktop Scene
  • Chip Set: TI TPA3255
  • Output Power: 300Wx2 @4Ω
  • Input Mode: RCA
  • SINAD: 88dB
  • THD: 0.003%
  • SNR: ≥110dB
From $69.99
2.0 CH Amp
Passive Speakers, Pre-Out
From $109.99
300W@4Ω
RCA, XLR, ¼”TRS
Speaker Output
<0.006%
≥123dB
From $109.99
2.0 Ch Amp
2x 300W@4ΩV
RCA, XLR, ¼”TRS
Speaker Output, Sub-Out
<0.006%
≥106dB
Fosi Audio TB10D Stereo Audio Amplifier - Fosi Audio
2.0 CH Amp
300W x 2
Passive Speakers
≤ 0.3%
≥ 90dB
≥ 108dB
Fosi Audio V1.0G Mini Stereo Audio Amplifier - Fosi Audio
From $69.99
2.0 Ch Amp
50W x2
Passive Speakers
≤ 0.04%
≥ 98dB
19V/4.74A
Customers praised this compact Class D stereo amplifier for delivering "clean," "powerful" sound with exceptional clarity and value. Many noted it exceeded expectations, with reviewers saying "sounds great" and highlighting minimal noise. Some mentioned relay clicking and high frequencies being slightly bright. Excellent customer service was frequently commended.
  • 5 stars: 223 (91%)
  • 4 stars: 22 (9%)
  • 1 star: 1 (0%)
Cristian (Romania)
Great little amp for office works well
Great little amp for office works well from 4 to 8 ohms. Its clear even on max volume. For best use a DAC or dongle usb to push 2V RMS on RCA , most equipments like phones or PC use less then 1 thus you arent getting the full power of it because the signal input is weaker.
Jonathan (United States)
Powerful, affordable, and sounds good!
This little amp is perfect for my semi-portable desktop setup that I run on top of my toolbox at work. Paired with a laptop, dongle DAC and some Polk outdoor speakers, it plays loud enough to annoy my coworkers and clean enough to satisfy my needs. It’s quite powerful for it’s size, and priced very well. I rarely turn the volume past 1-2:00. I would recommend for anyone looking for a small no frills amplifier that just works.
Gene (United States)
Solid, with one quirk ...
Updated review .. I finally received the unit after waiting a month. I suspect this delay is not the fault of Fosi, but the way FedEx and USPS now interrelate in a changing world.
The unit is solid, works as expected. I'm using it to drive a 90's eera Bose subwoofer that is designed to take full range input (L,R). THis is not a proper "sub" but it augments my 12" Cerwin-Vegas well, as they have real subs, but don't deliver the "punch" ... so this little amp is now making the Bose my "kicker" for bass and low mids.
It runs cool at the levels I choose to listen at. I wish the huge ventilation slots were not on the top though. I have the unit in a spot designed for it prior to receiving it, sitting a couple inches to the side of a Fosi P4 preamp. Thing is, I have an "odds and ends" basket ... literally, a basket ... sitting on top of these and that's the way I designed my little shelf/rack. The basket holds cables, adapters, and odds and ends I want on hand, but don't want to see. So instead of letting the basket block the vent of the V3, I made a little standoff, so it can breathe. This is convenient as the height of the V3 is slightly less than the comparable unit, the P4, which it is set next to. Why am I telling you all this? Cuz I was assuming that the two units, being so very similar in size are actually not the same. Not a big deal, but don't design your physical layout before taking note of the dimensions!
Pretty cool little amp.
One thing I like about it VERY MUCH is that it powers on with no interaction from me, as opposed to the P4 sitting next to it .. so no added button presses. I hate that I can't set the P4 to come on with the system power (power strip switch).
Bogdan (Bosnia and Herzegovina)
Best buy desktop AMP out there
I am very pleased with V3. got it with 48v 5A power supply. Plenty of power to drive my wharfedale 12.1i. Sound is clean and I dont hear it has any impact on sound signature for my speakers.
Its great little AMP. Recommend 10/10
Yankele (Ecuador)
Amazing value
I was looking around for a cheap amp to power up a pair of Klipsch kb15 that i got as a gift. Thought in setting them up on my computer to use them to play some music (im tired of headphones). Saw couple reviews and suggestions on youtube and i got very intriged (thanks a lot cheapaudioman). Bought a V3 it and it arrived today.
The construction is quite sturdy, elegant yet simple, the V3 will easily blend in any enviroment you place it.
I hooked it to my PC and wow, just wow.
The clarity that im getting from the speakers is amazing, the separation, revealing instruments that were muddled in my mind for too long on alexa devices, and cheap BT receivers.
The setup its pretty straight forward, make sure you got all required cables, cause there is none incluided in the package, just the amp and the power source.
Ive being listening to music non stop for at least 4 hours and im in love already.
s
sabboo (United Kingdom)
Stunning amp
I am using it to drive 150w 8ohm speakers in a decent sized room.
The sound quality is exceptional, even at low volumes.
The stereo seperation sucks you in, and the lack of any noise that shouldn't be there still amazes me well over a month later.
I really do recommend this amp. I bought the uprated power supply for mine.
Its compact size, and abilty to pump out the power will bring your old speakers back to life again.
JAG (United States)
Easy to Recommend
I recently decided to bring my old bookshelf speakers out of hibernation and needed an amp to power them. I saw a lot of very positive reviews for the Fosi Audio V3 and decided to try it. Long story short, it works and sounds great. I like the small size and the clean design. It also has a very high quality feel to it. If I had a nitpick, it would be that I wish it had a power switch separate from the volume knob. I have since also gotten the Fosi P4 preamp and the Box X5 phono preamp. I would also recommend those. Also, a consistent LED color and brightness between Fosi products would be appreciated.
Darko (Croatia)
A little Beast
The V3 surprised me immediately.
I bought it for surround/rear channel duties in my 5.1 setup, expecting a compact and efficient amp, but what I got was something that sounds much bigger and more refined than its size suggests.
The sound is clean, dynamic and controlled, with a very effortless presentation. Even at higher listening levels it stays composed and never becomes harsh or fatiguing.
What I especially like is how easily it blends into a multi-amplifier setup. In my system it works alongside ZA3 and BT30D Pro amplifiers and still feels perfectly at home sonically.
Build quality is excellent, the amp runs cool and the compact form factor makes placement very easy.
For anyone building a serious desktop, stereo or surround setup, the V3 is an amazing value.
Hans (Norway)
Great little amps
Does a massive job pushing 8 inch in-walls, clarity and basscontrol received a massive bump compared to previous amp. A bit shocked actually how big of an impact the amp has on sound, really noticeable on songs you know really well.
Mario (Argentina)
Truly impressed!
I bought it in September 2024 and I still maintain that it's the ideal amplifier for small/medium spaces. Its simple and clean design makes it even more appealing—just one knob to turn it on and control the volume, and a blue LED indicates that it's powered on. In design, they say less is more, and in this case, it applies perfectly.
All the materials are high quality.
The sound is another story altogether; the clarity and definition you can achieve are truly surprising. In my case, I have it connected to some Beovox S45-2 speakers, and it drives them without any problems. Highly recommended.
Eric (United States)
Great sound
Nice amp. Just waiting for my ne, luna. Cant wait to bring this to life.
Killer li'l amp
Opted for the bigger power supply to get all the juice it's capable of. Sounds great in my home office powering some passive Klipsch's.
Donald (United States)
V3 stereo made Polk 4 ohm sparkle!
I built boxes (see photos) for an old pair of Polk 200 watt 4ohm 6x9s with tuned passive radiators along with a 50 watt powered sub so I could have a garage set. They sounded good but I always thought more power than an 85 wpc Yamaha amp would really let them shine. Well the little Fosi with a 48V/5A power supply lit these up like the 4th of July. 5 stars all around for clarity, female vocals, that "just right" balance of punchy bass and twinkling treble, outstanding instrument separation, 3D image, wide soundstage, musicality and POWER. I normally listen at conversation level but experimenting with the volume I can tell you this class D amp could start a block party. I want to get another one for my Boston Acoustics towers in my listening room.
Donnie (United States)
V3 Stereo Amp
V3 stereo amp with Vanguard Scouts, wonderful combo, so open and musical!
Great Amp
Used as a replacement for an antique console. Works great.
Kristian (Germany)
Absolutely fantastic !
This one is really really a good thing. I woke up my 1992 B&W Matrix 805, after they have been unused for several years, because they sounded very terrible on my Yamaha R-S202D Stereo receiver.. now I found this type of mini amplifier, I've never noticed it before.. the fosi v3 was the best buy in the last years for me. I've never heard my speakers with such a powerful, clear, wide sound stage. Absolutely recommend this one, and better get it with the 48v/5A power supply.
Ammit (Serbia)
Perfect little amp
Best amp i ever heard under 200€. 32v 5A power supply not that loud, but with 48v it's perfect.
Tad (United States)
Great for the Money
Was looking for a cheap amp to pair with my expensive desktop speakers. This does the trick and then some. Enough volume to have a party at my desk. The volume control isn't perfectly linear (most of the "control" is in the first 50% of the knob turn), but the knob's action itself is smooth and satisfying to fiddle with. I recommend using banana plugs because the terminals are on the small side.
Daniel (Switzerland)
Sounds great without background nois
The two amplifiers P3 and V3 300W feed my two infinity alpha40 8 ohms. The volume from the mobilephone is good, but not too strong. With the minidisk, on the other hand, you can turn up the volume quite a bit. I use a 48V 5A power supply.
z
zoxy1955@gmail.com (Serbia)
V3
Savrsen odnos kvaliteta i cene. Odlican zvuk, preporuka
