IM4 IEM Accessories include 4.4mm balanced cable, 3.5mm cable with microphone, and D2 DAC.
High-purity wire, low signal loss, enhance sound quality—clear treble, full bass, wide sound field.
Gold-plated plug, anti-oxidation, stable transmission; soft wire, anti-tangle, comfortable to use.
Plug and play, no modification needed. Suitable for daily commute, Hi-Fi listening, calls, games.
Customers praised this balanced cable for delivering improved sound quality with more "punch" and precision. Shoppers noted it "sounds more complete" and provides "quieter and cleaner" audio with no noise. The soft, tangle-resistant cable fits comfortably. One customer experienced shipping delays.
  • 5 stars: 5 (83%)
  • 4 stars: 0 (0%)
  • 1 star: 1 (17%)
Sleepwalker (Germany)
Cherry on the cake for my Carbon 12
It's just a cable - right?
It's not just a cable, it is an upgrade in sound and usability. The 4.4 mm balanced cable upgraded my Carbon 12 on a higher level of usability (1st and most important fact: The 3.5 mm output of my DAP is faulty and I was forced to use the 4.4 mm output with an adaptor from 4.4 mm to 3.5 mm.) and improved the sound quality (slightly, but it sounds more "complete" - difficult to describe. The sound has more "punch" and slightly more precision.).
I really like the soft cable and its insensitivity against microphone effect. It fits perfect around my ears.
Unconditional recommendation!
John (Philippines)
MISROUTED ORDER
I DEMAND A FULL REFUND IMMEDIATELY for Order #77974! My package was misrouted to a city far from my correct delivery address, and it has been almost 11 days since I placed my order. This delay and poor handling are completely unacceptable! REFUND MY MONEY NOW! I WILL NOT ACCEPT ANY MORE EXCUSES OR DELAYS! 😡😡😡
Andrew (Canada)
Im not someone who writes reviews, but in this case I'm going to suggest this combination is a winner.
This iem dac combination is by far my top sounding, favourite pair, of iem's I own, and I own many! Also I have made many purchases from fosi audio and i have never had issues, I recommend.
DocHouse (Germany)
Awesome stuff
Great listening
Ruslan (Ukraine)
Fosi Audio IM4 , + 4,4 mm Balanced
In the budget segment, this is the best solution right now. If you're unsure which headphones to buy, get these and you'll know where to go from there. With the stock cable, they sound full-bodied, with some emphasis on the low frequencies. I also bought an additional cable, and the sound became more "mature," with more structure to the low frequencies. The signature didn't change much, which is good. Fosi pleasantly surprised me.
Gerry (United States)
Great upgrade
I’m a Fosi fanboy, so naturally I had to get this for my Fosi md3 , and it really makes a huge difference in the sound; it’s much quieter and cleaner with no noise. Also, kudos to the non tangled cable. It’s $36 , and well worth it.
