  • Adopt Texas Instruments TDA7498E chip, NE5532 op-amp. No pop, no audible noise, dead silent when nothing is playing through it;
  • Built-in low pass filter, 220W X 1(4 ohms, 20 Hz - 120Hz, 0.04% THD, 18db/octacce) for subwoofer, Small simple compact design but practical and powerful;
  • Advanced circuitry design, built-in speakers protection circuit, solid aluminum chassis for long time use;
  • The new version of TP02 has one more sub freq adjustment knob than the old version, and the others remain unchanged.
Quick tips:
Model TP-02
Output Power 220W for Subwoofer
Terminating Impedance 2Ω-8Ω
Input Mode RCA
Output Mode Passive Subwoofer /
Powered Subwoofer
Frequency Range 20-200Hz
THD ≤ 0.04%
SNR ≥ 98dB
Input Sensitivity ≤ 280mV
Device Dimension 5.12 x 3.54 x 1.58 inches
DC Input Range 12-24V
Power Supply 24V 4.5A
Fosi Audio TP-02 Amplifier x 1
AC Power Cord x 1
24V 4.5A Power Adapter x 1
Compare with similar items:
  • 5 stars: 10 (83%)
  • 4 stars: 2 (17%)
DM (Saudi Arabia)
Highly recomended.
Worth every penny. Paired with Fosi BT20A PRO and polk audio speakers. Sounds amazing.
DM (Saudi Arabia)
Highly recomended.
RAMESH (India)
Worth buying
Super
RAMESH
Worth buying
Super
EchoAudio (United States)
good little amp
good little amp
Eric (United States)
Packs a punch, don't even think twice about getting this!
I hooked this into a jbl 160 with a failed plate amp that houses an 8" 4ohm svc subwoofer. This little beast can easily overdrive that woofer at 60%. Played for about 10 minutes in the garage and the unit was cold to the touch. Next I'm going to try two 12" dvc subs at 2 ohm. I have no doubts that it will be up to the task. Very impressed. Crazy how far amp technology has come since I was a kid. Only test now will be longevity. I'll try to update if anything changes.
Dorian (Romania)
Excelent
Very powerful for bass shaker Dayton Basx A300 . Good good product
Dorian (Romania)
Excelent
Sam (United States)
Great amp for my Lii audio w21 woofer
This replaced a cumbersome plate amplifier and I lost nothing in performance
Sam (United States)
