  • Each package contains a pair of fully tested and matched vacuum tubes (2 PCS).
  • 5654W vacuum tubes for T20, P1, P2, Box X2Box X4. Substitute for 7-pin 6AK5/6AK5W/6Zh1P/6J1/6J1P tubes. It can also directly replace WE-403A/403B/EF95 and ordinary 5654.
  • 6J1, 6CB6A, 6Ж3N, 6J5, 6Ж5N tubes are compatible with audio devices such as BOX X2, BOX X4, P3, GR40, GR70, MC331, and T20X MKII.
  • Note: Replacing the wrong type of tube may damage your amplifier. If you are not sure this 5645W can be used as a replacement for your audio device, please check with your amplifier manufacturer.
  • It has a fuller, wider sound stage. The treble is smoother and the bass is a little bit tighter. And you can hear some details that you did not hear before while listening to more complex music.
  • Every package you get goes through our careful packaging. With 18 months warranty. If you have any questions, please feel free to contact us.
