  • Advanced circuitry design, built-in speakers protection circuit, solid aluminum chassis for long time use, small size, good looks, simple functionality, and excellent sound quality;
  • Best for bookshelf/computer/desktop/speakers in your room, connect to your Phone/MP3 player/DC/TV/Echo Dot as input, 50W X 2(4 ohms, 20 Hz - 20 kHz, 0.04% THD) can drive 2Ohm - 8Ohm speakers;
  • Simple compact design but practical and powerful, Adopt TI TPA3116D2 chip to get clear and clarity sound, no audible noise, dead silent when nothing is playing through it;
  • Aluminum shell and Aluminum knob to sure high quality come to a 19V power supply that can fit with the amplifier well. 24-month warranty, you can return the item if you have any problems;
Fosi Audio V1.0G 2 Channel Stereo Audio Class D Amplifier Mini Hi-Fi Professional Digital Amp for Home Speakers 50W x 2
Model V1.0G
Chip Set TPA3116
Output Power 50W x2@4Ω
Terminating Impedance 2Ω-8Ω
Input Mode RCA
Output Mode Passive Speakers
THD ≤ 0.04%
SNR ≥ 98dB
Input Sensitivity ≤ 280mV
DC Input Range 12-24V
Power Supply 19V 4.74A
Fosi Audio V1.0G Amplifier x 1
19V 4.74A Power Adapter x 1
Video
Compare with similar items
Customers praised this mini stereo audio amplifier for working well with good build quality and performance. Some noted minor issues including slight crackling when adjusting volume and radio frequency interference from the switching power supply between 27-30 MHz, particularly affecting radio receivers.
  • 5 stars: 3 (43%)
  • 4 stars: 4 (57%)
Nikolai (Norway)
Works well
I bought this amplifier at first but later got a new one to suit my needs, but this worked well for when I had it
Nikolai (Norway)
Works well
Anonymous (United Kingdom)
What can I say
Excellent amp
Jacob
A fine product
The amplifier works as expected, with no audible noise apart from a slight crackling when adjusting the volume knob
Jacob
A fine product
Neoklis (Cyprus)
Fosi Audio V1.0G
Package arrived int time and undamaged.
Amplifier looks well made in good enclosure and works well.
Only problem I have, as a Radio Amateur, call sign 5B4AZ, is powerful noise interference between 27 and 30 MHz that is apparently produced by the switching power supply. This problem existed with a similar amplifier of another make I had before the Fosi. Switching supplies and amplifiers don't agree with sensitive radio receivers but seem unavoidable. :-(
Neoklis (Cyprus)
Fosi Audio V1.0G
