Fosi Audio P4 Preamplifier
The Compact Control Hub for
Your Home Audio System
Buy Now
Buy on Fosiaudio
Buy on Aliexpress
Buy on Amazon
Buy on eBay
The Compact Control Hub for Your Home Audio System
Buy Now
The P4 is a mini preamp supporting three inputs, developed based on extensive feedback
from users worldwide after the launch of the V3 stereo amp.
V3 stereo amp
We will continue to listen carefully, record your feedback promptly, and make efforts to turn your ideas and suggestions into reality.
I would pay $150 for a pre that had 2-3 RCA inputs a real sub out and with volume, bass and treble. -Northa40 from ASR
Now for this pre-amp, lโ€˜d be more impressed if it didnโ€™t have tubes, and maybe more inputs. -Jim  from ASR
SS preamp that would allow for multiple inputs, with a remote. -Joe Smith from ASR
If you want to make a real preamplifier, it should have at least 2-3 inputs. -Zek from ASR
It would be perfect if it had bypass and a remote... and actually worked properly. -TonyJZX from ASR
Reviews are in...
Anche in questo caso le prestazioni sono decisamente adeguate al prezzo e la comoditร  del potenziometro motorizzato รจ una chicca da non sottovalutare.
The Fosi P4 surprises with incredibly low cost while providing features such as motorized volume control and excellent performance.
Crafted with Care, Small Yet Powerful
DAC Converter
Triple RCA Inputs
Triple RCA Inputs
Remote Control
Remote Control
All-Aluminum Alloy
Best Preamplifier
Tone Control
Tone Control
Motorized Potentiometer
Replaceable Op-Amp
Replaceable Op-Amp
Click to Spin
The Mini Control Hub for Home Audio System
Easily connect up to three audio sources, with one-touch input switching for ultimate audio freedom
Home Audio P4
Best Preamp
High-Precision Motorized Analog Potentiometer Integrated
Not only provides a smoother volume adjustment experience, but also further reduces noise and distortion, delivering a purer soundscape for you
hi-fi
Practical Features with Ease of Use
Best Preamp
Tone Control Bypass
Bypass the tone control to enjoy the purest high-fidelity sound.
Three-level Gain Adjustment
Match different output levels from audio sources for improved sound quality.
Pre-out Port
Expandable connection for a powered subwoofer.
Bass and Treble Control
Achieve personalized tuning with central detents for better sound customization.
Multi-Function IR Remote Control
Easily adjust the volume, switch sources, and control the tone without leaving your seat, enjoying a convenient audio experience
All-Aluminum Alloy CNC Construction
Metallic texture, compact and refined, with enhanced resistance to electromagnetic interference
Series Design, Perfectly Paired with the V3 Amp
With a harmonious and unified appearance, it elevates both the visual and audio experience of your sound system
V3 Amp
Visible Exceptional Sound Quality
Channel
2.0
RCA*3
RCA, Pre-out
โ‰ฅ 110dB
Dynamic Range
โ‰ฅ 110dB
โ‰ค 0.003%
Crosstalk
โ‰ฅ 105dB
Noise Floor
โ‰ค 9ฮผV
Tone Adjustment Gain
ยฑ12dB
Frequency Response
20Hz-20kHz(ยฑ0.1dB)
DC 12V/1.5A
