$140 Gets You More Than You Think
Matt Coykendall
Finally, a Cheap CD Player that Makes Sense!
Forever Analog
Prezzi Umani per l'Hi-Fi
Riccardo Palombo
CDs sind zurück?! Macht der Merak sie wieder spannend?
andisolo
Matt Coykendall
Forever Analog
Riccardo Palombo
andisolo
Wake Your CD Collection Again
Fosi Audio Merak CD Player
Merak takes its name from Beta Ursae Majoris, a star in the constellation Ursa Major. It has often been used as a reference point for locating the North Star, symbolizing guidance and direction. Inspired by this meaning, we hope Merak becomes a point of reference in your listening journey—bringing more precise imaging and a more immersive experience.
Seamless System Integration
With optical and line outputs, it connects easily to DACs, amplifiers, or active speakers. The included remote control allows convenient input/output switching and track selection. A 12V Trigger output enables synchronized power with Fosi devices like ZD3 and ZA3.
Precision mechanism and servo system ensure accurate disc reading, stable tracking, and smooth playback with reduced disc wear.
Precision Mech & Servo System
Gapless Playback
Gapless playback eliminates track gaps, making it ideal for live recordings and symphonic music.
Built for Daily Use
Four Playback Modes
Easily switch between Play Once, Repeat One, Repeat All, and Shuffle using the front panel controls or the remote.
Flexible Playback Control
Lid-Open Auto Stop
Automatically stops playback when the lid is opened, preventing disc rotation and reducing mechanical stress during operation.
Playback Stops When Opened
ESP Anti-Skip
ESP minimizes playback interruptions from vibration, ensuring stable performance during movement or external disturbances.
Electronic Shock Protection
Plug and Play
Equipped with a 3.5mm headphone jack delivering up to 210mW ×2 of output power. Simply plug in your headphones and enjoy your own private listening moment. Its compact design fits easily on a bedside table or beside the sofa, letting you fully relax and unwind with music.
Simple Setup, Instant Playback
Curated Audio Chipset
Built-in CS43131 DAC paired with 2 TPA6120 op-amps design, Merak supports up to PCM 16bit/96kHz audio. With a 124dB SNR and 0.0009% THD, it delivers a clean signal faithful to the original CD recording.
Greater Fidelity
CD Ripping
Merak features one-touch CD ripping, saving original CD audio as 16bit/44.1kHz WAV files to a USB drive without loss of quality. Equipped with a USB-A input, supporting USB drives up to 128GB for direct music playback.
USB Drive Playback
As Seen On
Precision CD Transport: Optimized servo system ensures accurate disc reading, smooth playback, and reduced wear, supporting stable long-term performance and consistent audio output. All-in-One Audio Design: Combines CD player, DAC, and headphone amplifier in one unit, simplifying setup while maintaining low distortion and clear signal reproduction. CD Ripping & USB Playback: Supports CD ripping to USB and direct playback, enabling easy conversion to digital files and convenient access without additional devices. Flexible Output Connectivity: Multiple outputs support headphones, amplifiers, and active speakers, allowing seamless integration into desktop systems or larger audio setups. ESP Anti-Skip Protection: 60-second buffering reduces interruptions from vibration, maintaining stable playback and improving reliability in movement or less controlled environments.
The Fosi Audio Merak CD Player is a compact, desktop-style Hi-Fi device designed to blend traditional CD playback with modern digital features.
How to check USB drive format?
Windows: This PC → Manage → Disk Management → Check USB format Supported: ✔ FAT32 Unsupported: ✘ NTFS Recommendation: Most new USB drives are preformatted as FAT32.
Does playback stop when opening the CD lid?
Yes. Reason: Merak uses Hall sensor detection. Behavior: Opening the lid during playback immediately stops playback. Status: ✔ Normal design behavior
Does Merak meet environmental standards?
Yes. Compliance: ✔ ROHS 2.0 ✔ REACH
Does Merak support SACD?
Partial support. Supported: ✔ CD layer only Unsupported: ✘ SACD high-resolution layer
Why use a dedicated CD mechanism instead of a DVD mechanism to play CDs?
Dedicated CD mechanism is specifically optimized for audio playback, including a more precise clock system, a more stable reading structure, and an optimized digital signal path. Compared to a general-purpose DVD mechanism, it typically delivers clearer audio detail and a more stable soundstage performance.
Why is ESP anti-shock protection included in a desktop CD player?
Although ESP is more commonly used in portable devices, it is included for the following scenarios: 1. Users may use the device in a car, where vibrations can affect playback stability; 2. On a desktop, strong bass or high-energy music may still cause vibration that impacts disc reading stability.
Compact, well-built tabletop CD player praised for "superb" sound quality and versatile connectivity options. Customers loved the optical output, USB ripping capability, and gapless playback. Common praise: "great value," "excellent clarity," and "fantastic sound." Minor issues noted: track fade-in clipping, slow ripping speed, scratches on plastic lid, and occasional compatibility concerns with external DACs.
5 stars: 188 (77%)
4 stars: 42 (17%)
3 stars: 5 (2%)
2 stars: 3 (1%)
1 star: 6 (2%)
Firman (Indonesia)
Excellent Sound Quality and Great Value
I’m very satisfied with the Fosi Audio Merak CD Player. The build quality is excellent, the design is elegant, and the sound quality is clear and detailed. It works as expected and provides a great listening experience. Definitely a great value for money. Highly recommended for anyone looking for a quality CD player!
Tim (Canada)
Perfect player
Love my Merak!!
So glad I boxed my cd’s up 20 years ago & kept them.
I’m having so much fun rediscovering my collection & the Fosi Merak cd player is a joy to listen to.
My system is a Merak into a ZD3 then into two ZA3’s & out to a pair of Klipsh bookshelf’s & matching sub…it sounds amazing.🤗
Thanks Fosi!!
Gilbert (United States)
Merak do Rock
I’m listening to cd’s again because of this merak cd player, gives a very good quality output music..worth the money, i even ordered fosi nano disc player for portability..they all have a good sound output to my speakers
Pinkie (Colombia)
Very good quality and very easy to use! with potential to be even better
I've been using the merak time to time and I can say that the disc and flash drive playback is so good, the sound that provides is very clean and it's particularly colored to any side. That being said, that can lead to having no mercy with bad or poor quality recordings, so that's where I would have liked to have a function where you could at least at least up or down the bass and the treble built in the merak itself and not having need for a pre amp to do that. Other than that, a thing that I'd change on the design itself it's the volume slider for a volume nob at the front, but obviously that would meant that you'd have to change the layout of the buttons at the front, and right there is where you NAILED, because it's so easy and simple to use just because of that, no weird button combos to access a funtion, all you need for non friction playback is right there and the maximum tricks that it has is only hold certain buttons for more that 2 seconds. And the last things I wanted to mention are:
The remote control and the screen
With the remote, I have no issues with it but ONE single doubt, why the buttons at the right and left bottom corners aren't given with any funtion at all and that's why I believe we could have some 2 funtions more for the player. And for the screen, I just think would be nice to have some text showing when playing files such as mp3 or flacs like the title of a song passing through the screen when starts to play, but those are just little nitpicks
In conclusion it's a fantastic products with an amazing sound and a really stunning build quality and a such a pretty design, keep pushing on that direction Fosi!
FENNELLWILLIAM (United States)
Game Changer & Best in Its Class!
I’ll keep this simple. I was ready to be mildly impressed, but I was completely won over by this high-quality, stylish CD player.
In the past year I have tried and tested six different players by various makers, and Fosi Audio Merak is the undisputed pound-for-pound champion for my money. The playback has been flawless, excellent connectivity, straightforward controls including a well designed remote control, and the display is excellent.
If you’re looking for a solid and great looking player developed with real world users like you in mind, then I highly recommend the Merak.
I’ve been playing my favorite CDs on mine ever since it arrived. Enjoy your music and happy listening!
Alfred (United States)
Near Perfect!
This player performs amazingly well at any price point.
Ez (United Kingdom)
Great quality and value
JazzPirate (United States)
Great Player
Luis (United States)
Andrew (Australia)
Love my Merak CD Player
Anyway to the review.
AndrewT
Michael (United States)
The CD Player I was missing
DanR2C (United States)
Great product!
I did see some sound improvements from streaming, like the music was more full or had more data. It may also just be in my head if I’m honest hahaha regardless it has been amazing and I 110% recommend you get one.
It’s not perfect, that latch is a mess and should really have a magnet or even just a spring with some tension or a clip or something. It just feel loose and I’d it clicked or latched or clipped close, it will feel better.
I see no use for the USB and ripping a CD, like come one, I’m getting this so I have and use physical media, not as a device to have digital files and stream them from a home server or something, plus even I did that, with no Meta data, it’s like going back to 1999 and manually adding all this to files.
GP. (Canada)
The Fosi Audio Merak is one of those rare pieces that just works—and keeps working the way you expect. Sound quality is clean, detailed, and far more refined than you’d expect at this price. Whether through headphones or a system, it delivers a solid, enjoyable listening experience without fuss.
Where it really stands out is the overall experience around the product. Fosi’s customer service is responsive, helpful, and actually present—something that’s becoming rare. Questions get answered, support feels human, and you’re not left chasing solutions if you need help. That level of follow-through adds real value to the purchase.
The design is simple and well executed -well deserving the Red Dot Award, with the top-loading mechanism adding a tactile, satisfying touch. It’s compact, versatile, and does exactly what it promises without overcomplicating things.
Curt (United States)
Great little CD Player!
Tom (United States)
Exceeded all expectations
Julio (Spain)
REPRODUCTOR DE CD PORTATIL DE UNA GRAN CALIDAD
Lo primero decir que viene muy bien presentado en una caja muy bonita, lo he probado con auriculares primero reproduciendo un cd y después con un pendrive con formato flac y suena de maravilla. Después lo he conectado a un amplificador y lo he vuelto a probar con un cd y con el pendrive, decir que este reproductor suena tan bien como otros reproductores mucho mas caros, además es muy silencioso, lo recomiendo.
Vladislav (Czechia)
Fosi merak
Jsem mile překvapen cd přehrávač je super mohu jen vřele doporučit vše naprosto v pořádku
Scott (Canada)
Almost perfect
It’s so refreshing to see cds making a resurgence…. I needed a simple no nonsense easy to use cd player and a way to get my cds onto my iPhone without a computer… this player checked all my boxes and doing so while being super cool looking and compact it’s better than I expected and I’m super happy with my purchase it’s nice to see a company put such attention to detail …even small ones and quality at a decent price …. Like I said in the title almost perfect…. The only thing I don’t like is the fact it doesn’t transfer or read the titles of the songs …. It’s a pain in the but having to do that manually…. I’m not sure what chip or tech you would’ve had to do to accomplish that I’m far from a computer guy but other than that it’s an amazing little cd player
Fast,Free Delivery
24h All-Day Support
