  • Input Mode: MM+MC RCA
  • Output Mode: RCA
  • THD: ≤0.009%
  • SNR: ≥ 92dB
  • Power Supply: 16V/1A
  • BОX X5 Phono Preamp x 1
  • 16V 1A Power Adapter x 1
Products Fosi Audio BOX X1-MM Phono Preamp MM Turntable Preamplifier
Active Speakers + Headphone
Bass & Treble Control
≥ 70dB
≤ 0.08%
12V/1.5A
Fosi Audio Box X2 Phono Preamp for Turntable Preamplifier HiFi MM Phonograph Preamplifier for Record Player - Fosi Audio
RCA+3.5mm
Active Speakers
≥ 98dB
≤ 0.1%
12V/1.5A
Fosi Audio Box X3 Bluetooth Phono Preamp for Turntable Phonograph Preamplifier With 5725 Vacuum Tube - Fosi Audio
Bluetooth + AUx+ RCA
Active speakers
≥ 70dB
≤ 0.1%
12V/1.5A
Phono Preamp & Headphone Amplifier with JAN 5654W Vacuum Tubes for MM Turntable Phonograph Preamplifier for Record Player with Volume Bass Treble Control Hi-Fi Pre Amp Fosi Audio Box X4
RCA+3.5mm AUNo
RCA+3.5mm AUNo
≥70dB
≤ 0.1%
12V/1.5A
Based on 45 reviews
91%
(41)
4%
Dipl.-Ing. Michael Bönninghoff
A dynamic monster
Great item. What a wonderful performance this little baby is able to provide. After a little time of burning in this honey makes it unbelieveable good. Buy it!
Randy
Deze fosi pre amp helpt me mijn vinyl collectie opnieuw te ontdekken. Ik luisterde vinyl via de mm-aansluiting van mn Marantz PM7000n maar dit is echt een wereld van verschil. Met name op het gebied van stemmen, dynamiek en een open geluidsbeeld.
Outof Into
Budget cost but not budget sound quality
The Fosi X5 was bought to provide a 2nd moving coil phono input for the 2 turntables I use.
I already own an Ifi Zen phono preamp and I am happy with its performance.
I decided to buy the Fosi x5 phono preamp after hearing, reading and seeing ( on YouTube ) good reviews about it.
The Ifi Zen is a good value for money phono stage being very quiet, with a transparent sound quality demonstrating a clean treble, detailed midrange and good bass depth and articulation. Also it's sufficiently versatile to cope with the Ortofon and Audio Technica cartridges that I use.
These qualities are matched by the Fosi, plus the Fosi's bass response sounds slightly more powerful and defined and its overall sound has slightly more weight and fullness.
Despite its low cost, its sounds far better than its budget pricing would suggest which makes it an excellent value for money phono preamp. Highly recommended
f
frank rango
It works very well
I was using an old 80's receiver as a RIAA eq/preamp. Fosi unit was a big improvement for an extremely reasonable price
Patrol
Phono preamp Fosi Audio Box X5
A very good product that outclasses the more expensive competition. I have a Project Debut Pro S turntable and I compared the Box X5 directly with the ifi Zen Phono V2. Fosi gave more space, nice bass, so it stayed with me for longer. I didn't need a subsonic filter. As for the noise, it will appear only at an extreme volume level, close to the maximum, so it's a negligible issue (with the ifi Zen there was no noise at max vol). Finally, I'll add that Fosi support works very well.
