Fosi Audio Box X3 Bluetooth Phono Preamp for Turntable Phonograph Preamplifier With 5725 Vacuum Tube - Fosi Audio
$79.99 USD
$79.99 USD
$79.99 USD
Model BOX X3
Output Interface RCA output
THD ≤ 0.1%
SNR ≥ 98dB
Product Weight 0.71 lb/320g
DC Input Range 12V
Power Supply 12V 1.5A
Box X3 Phono Preamp x 1
5725 Vacuum Tubes x 2
12V 1.5A Power Adapter x 1
RCA Cable x 1
Download BOX X3 User Manual
Based on 7 reviews
57%
14%
29%
Gary B
Price, function, and sound satisfaction
I find the sound of the preamp through the phono input/output to be very neutral and clean. I really like the simplicity of the tone adjustments and being able to isolate them to each source, especially phono.
I didn't have a bluetooth option prior to integrating this component into my system, so the dual functionality of bluetooth/phono was very welcome. The bluetooth side of the box X3 has the same pleasant neautral sound profile. Functionality is rudimentary, and no frills. I prefer warmer sounds, and it's so easy to dial that in or out with the X3.
Since incorporating the Box X3, I have also picked up a wiim ultra. The wiim also has both phono and bluetooth functionality. Attempting to reproduce the clean and neutral sound of the Box X3 with the phono and bluetooth inputs of the wiim can be obtained by extensive EQ and settings adjustments. However, the effort required to get the wiim to do what the Box X3 does naturally are why the X3 stays part of my setup.
The Box X3 is another clean, simple, low cost solution in the FOSI lineup.
Joshua Miller
Box x 3
Love it works flawless
Yuwei LIU
Good enough for this price
Drx
Almost satisfied
Pedro Aragão Barros
