8th Anniversary | 15% Off w/ code 8TH15
- MM & MC Cartridge Compatibility
- 4 Gain Settings: 38-66dB
- Precision Audiophile Components
- Aluminum Alloy Chassis
- One-Touch Power & Cartridge Switch
- Input: MM/MC RCA; Output: RCASNR≥92dB; THD≤0.009%
- Frequency Response: 20Hz-20kHz(±0.015dB)
- High Performance: The BOX X5 phono preamp is compatible with both MM and MC cartridges, featuring 4 gain settings and an excellent precise RIAA equalization to provide a clean, direct pass-through of a signal when paired with your turntable
- Audiophile-Grade Components: This preamp utilizes a variety of materials such as 2% Precision Polyester Film Capacitors, Green Sleeve Copper Lead Audio Capacitors, 0.1% High-Precision Film Resistors, OPA1612 Op-Amp, Gold-Plated RCA Jacks, and more. It picks up subtle and finite detail produced from it and delivers a truly warm and inviting sound
- Multiple Gain Settings: With 4-Level gain adjustment Asettings of 38/48/56/66dB, the preamplifier accommodates both MM & MC cartridge types, meeting a variety of needs. This enhances your phono stage and helps in rebuilding the vintage stereo sound
- Mini and Exquisite: It's built around a minimalist yet functional design featuring an all-aluminum alloy chassis. When paired with the V3 stereo amplifier, the BOX X5 can bring out the best in your vinyl playback, enhancing its frequency response and dynamic performance
- User Friendly Design: It has an easy-to-use one-touch power button, gain control, and a convenient toggle switch to switch between MC and MM cartridges. In addition, the grounding port ensures that the connection is secure
- Input Mode: MM+MC RCA
- Output Mode: RCA
- THD: ≤0.009%
- SNR: ≥ 92dB
- Device Dimension: 4.1 x 6.5 x 1.4 inches
- Power Supply: 16V/1A
