  • 2.1 CH Wireless DAC Hifi Amplifier with EQ Control. MAX Power Output up to 120Watts x2@4ohm. DA2120C can drive most home bookshelf/desktop/outdoor(passive) speakers and powered subwoofers, offering low distortion and acoustically accurate audio reproduction. The bright digital LED display lets you see the settings you change easily and remote control for hassle-free adjust the inputs mode/volume/bass/treble.
  • DA2120C high-performance integrated stereo digital amplifier adopts Texas Instruments TAS5352A chip, designed to drive a 4-Ω bridge-tied load (BTL) at up to 120 W per channel with low harmonic distortion, low integrated noise, and low idle current. The TAS5352A has a complete protection system integrated into the chip, safeguarding the device against a wide range of fault conditions that could damage the system.
  • 2-in-1 High-Performance DAC Power Amplifier with Multiple Input Modes. DA2120C installed in a quality aluminum enclosure supports Bluetooth/RCA/PC-USB/Coaxial/Optical Input, easy installation to build a stereo sound system.
  • DA2120C Bluetooth 5.0 amplifier delivers sound in sync, so you can enjoy the freedom of wireless and high-fidelity streaming music. It reduces delay and improves the end-to-end speed of the audio transmission, resulting in high-quality, synchronized sound, so you never miss a beat. With a 6dBi high gain antenna for long-range streaming up to 65 ft(20m).
  • What You Get: DA2120C stereo amplifier x1, Bluetooth antenna x1, 32V/5A power supply x1, remote control x1, PC-USB Cable x1, Optical Cable x1, user manual x1, our worry-free 24-month warranty, and friendly customer service.
    multiple input of Bluetooth amp
    Bluetooth 2.1 Channel Amplifier
    Model DA2120C
    Output Power 2 × 125W at 10% THD+N Into 4 Ω
    2 × 100W at 10% THD+N Into 6 Ω
    2 × 80W at 10% THD+N Into 8 Ω
    Bass frequency 20Hz-200Hz
    THD ≤ 0.01%
    SNR ≥ 105dB
    USB Chip Cmedia CM6642 SUPPORT 24bit/192Khz
    Amplifier Chip American TI TAS5352A
    Bluetooth Chip Qualcomm QCC3031 Bluetooth 5.0 chip supports aptX, aptX-HD, SBC, AAC
    DAC Chip American Cirrus CS8422 chip USB, coaxial optical fiber Supported sampling rate 24bit/192Khz
    Device Dimension L180*W130*H38mm (7*5*1.5in)
    System Supported XP/W7/W8/W10/MAC/Linux
    Power Supply 32V 5A
    DA2120C Amplifier x 1
    32V 5A Power Supply x 1
    Remote Control x 1
    USB Cable x 1
    Optical Cable x 1
    AC Cord x 1
      Based on 14 reviews
      64%
      (9)
      36%
      (5)
      Vlamimirs Iciksons
      Veru impressed!.
      Compact,reliable and excellent sound guality. The Fosi 2120C easily drives my speakers and looks great too.Clean,detailed audio, stabile Bluetooth, and solid build. Highly rekommend the Fosi 2120C!
      Robert D Kirk Jr
      Power House Amp
      This is the second time I've purchased this exact amp; first for my gym and secondly for my gazebo. The first one is paired with Kicker outdoor speakers and a 12" Polk subwoofer for tremendous sound quality and instrument's distinction. This new amp is paired with the same speakers and a DaytonAudio 10" subwoofer with a unique design for my particular need. The amp powers my systems beautifully with a robust quality that satisfies this audiophile's demands!
      Dan Dapelo
      Great Sound and Worth the Price!
      I bought this to place in our office with some Klipsch RF-42ii - the sound is great! The DAC is better than what I had, which has brought great life to my music over Bluetooth. The remote is a handy feature for switching between BT and my XBox via Optical. The EQ takes a bit to dial in, but once I got it set up - the setup has been a welcome change in our office workspace.
      Sanjeet Saroha
      Good product, good looking
      Lifelong audiophile
      Great amp! the ONLY Fosi amp worth buying (I’ve tried many newer ones and they’re junk)
      I use this unit with a $2000 DAC through AUX RCA inputs a powered subwoofer and multi thousand dollar speakers
      The sound is dynamic and detailed
      You have the ability to voice your subjective preferred sound via bass and treble controls with the added bonus of 5 equalizer settings 5 stars
      🌟 it has definition and dynamic slam rivals many $1000 offerings
