The DA2120C is a high-performance integrated DAC and stereo amplifier, delivering up to 120W per channel (4Ω load). It easily drives most home bookshelf speakers, desktop speakers, outdoor passive speakers, and powered subwoofers—offering low distortion and acoustically accurate sound reproduction for a truly transparent listening experience.
Clear, Intuitive Operation
A bright digital LED display lets you view all settings at a glance. The included remote control provides hassle-free access to input mode, volume, bass, and treble adjustments.
Premium Texas Instruments Amplifier Chip
Built around the Texas Instruments TAS5352A chip, designed for 4-Ω bridge-tied load (BTL) applications, delivering up to 120W per channel with low harmonic distortion, low noise, and low idle current. The chip integrates a complete protection system to safeguard the amplifier against a wide range of fault conditions.
Multi-Input, 2-in-1 DAC + Amplifier
Housed in a high-quality aluminum enclosure, the DA2120C supports Bluetooth / RCA / PC-USB / Coaxial / Optical inputs, making it easy to build a versatile stereo sound system.
Bluetooth 5.0 with Synchronized High-Fidelity Streaming
Equipped with Bluetooth 5.0 for low-latency, high-speed audio transmission, ensuring perfectly synchronized sound. Enjoy wireless freedom without compromising on fidelity. The 6dBi high-gain antenna provides stable streaming over distances up to 65 ft (20m).
Package Contents
DA2120C stereo amplifier ×1, Bluetooth antenna ×1, 32V/5A power supply ×1, remote control ×1, PC-USB cable ×1, optical cable ×1, user manual ×1
Worry-Free Support
Backed by a 24-month worry-free warranty and friendly customer service for complete peace of mind.
    multiple input of Bluetooth amp
    Bluetooth 2.1 Channel Amplifier
    Model DA2120C
    Output Power 2 × 125W at 10% THD+N Into 4 Ω
    2 × 100W at 10% THD+N Into 6 Ω
    2 × 80W at 10% THD+N Into 8 Ω
    Bass frequency 20Hz-200Hz
    THD ≤ 0.01%
    SNR ≥ 105dB
    USB Chip Cmedia CM6642 SUPPORT 24bit/192Khz
    Amplifier Chip American TI TAS5352A
    Bluetooth Chip Qualcomm QCC3031 Bluetooth 5.0 chip supports aptX, aptX-HD, SBC, AAC
    DAC Chip American Cirrus CS8422 chip USB, coaxial optical fiber Supported sampling rate 24bit/192Khz
    Device Dimension L180*W130*H38mm (7*5*1.5in)
    System Supported XP/W7/W8/W10/MAC/Linux
    Power Supply 32V 5A
    DA2120C Amplifier x 1
    32V 5A Power Supply x 1
    Remote Control x 1
    USB Cable x 1
    Optical Cable x 1
    AC Cord x 1
