  • 2 Channel AmplifierMini Vintage Amp: Crafted for music lovers, this VU meter amplifier harmoniously combines retro charm with contemporary design. Dive into the HiFi world with its superior sound quality and a powerful output of 200W. Experience a musical journey through time, where nostalgia harmonizes with audio perfection.
  • Effortless Setup: The MC101, featuring Bluetooth 5.3 and RCA wired connectivities, is versatile for various scenarios and easy to configure. Its user-friendly design includes automatic Bluetooth reconnection and a simple manual pairing reset, ensuring a smooth and uninterrupted wireless music experience.
  • Visual Dashboard: The VU meter combines aesthetic appeal with unique functional features. The pointer in the meter dynamically swings with changes in the audio signal, helping you adjust the audio volume in real-time to prevent overload and distortion.
  • Personalized Tuning: The MC101 features tone adjustment knobs, allowing for precise tuning of bass and treble gain to tailor your preferred sound. Additionally, the built-in central detents facilitate easy restoration to the sound's original character.
  • Refined Craftsmanship: More than just its captivating look, the MC101 boasts a CNC-machined, all-aluminum alloy construction, ensuring both longevity and a luxurious feel. Experience the superior quality in every touch, complemented by the peace of mind that comes with Fosi Audio's 24-month warranty.
Model MC101
Amplifier Chip Texas Instruments TPA3116 x2
Output Power Maximum 100W x2@4Ω
Input Mode Bluetooth + RCA
Output Mode Speaker Output + Pre-Out
SNR ≥100dB
Dynamic Range ≥100dB
THD ≤0.03%
Frequency Response 20Hz-20KHz(+1.8dB)
Bluetooth Device Name Fosi Audio MC101
Bluetooth Version 5.3
Bluetooth Connection Range 10-15 meters
Bluetooth Audio Codec SBC/AAC
Voltage Range DC 12V-24V
MC101 Bluetooth Power Amplifier x 1
24V/4.5A Power Adapter x 1
Customers praised this compact stereo amplifier for its "warm, smooth" sound quality and excellent value. The VU meter adds retro charm, though some noted low sensitivity. Shoppers appreciated the versatile Bluetooth and RCA inputs, solid build quality, and ability to drive various speakers. Some mentioned it's best for small rooms, with one reporting VU calibration issues.
  • 5 stars: 45 (85%)
  • 4 stars: 7 (13%)
  • 1 star: 1 (2%)
Jorge (Mexico)
Compact, Warm and Surprisingly Enjoyable
I really like the **Fosi Audio MC101**. The display gives it a very nice modern touch, and the sound is warm, smooth, and very enjoyable.
I have it in a small library at home, where its compact size fits perfectly. It is connected to a **Bose Acoustimass system**, and when I want to listen to music without disturbing anyone else, that is where I go.
I also have it connected to a **WiiM streamer**, and the results have been incredible. It is a simple, compact setup, but the sound quality and overall experience are much better than I expected.
For a small room or secondary listening area, the MC101 is a great little amplifier with a lot of charm.
Jorge (Mexico)
Luke (United States)
Impressive
Bought to pair with my Polk T15 speakers and my Bluetooth turntable. Paired easily, sounds great, and looks great on my fireplace mantle.
Impressive
John
Excellent! Took me all of 10 minutes to incorporate into my system. Sound is excellent. Drives two NHT bookshelf speakers with umph to spare.
Anonymous
Nice build and sound. Maybe headphones port?
מ
מוריאל
a
allears (United States)
Brings my old stereo system into the new millennium for less than $100!
I was looking for a way to bring my elder stereo system into the current millennium. The heart of the old system is an ancient Harman-Kardon 330A receiver probably made in the 50s, still sounds great but no way to connect easily via bluetooth. I looked at just a bluetooth receiver but finally decided on this excellent little fosi MC101 combo amp and BT receiver. It's perfect and a great value in many ways. A couple of comments after living with it for a week or so:
Just out of the box, the unit is tiny but feels very substantial, metal case, nice rubber feet, and has some heft to it. The connectors are all very solid-feeling as well. The knobs also feel very authoritative when you turn them, tight and right. It feels like great quality when you handle it.
Installation is super easy BUT I had never encountered the dual-type output connectors and was a bit afraid of breaking them. They will accept a banana plug or a bare wire, but to attach the bare wire you have to unscrew the clear plastic cap. These caps are on really tight, as they should be for shipping, so after I was sure that was the right thing to do, I turned them hard and they finally came off so I could get to the little hole in the base of the connector, push the bare wire in, and re-tighten the cap. It is easiest to take them completely off to attach the wires. You might need like a jar opener plastic thing to wrap around them to turn them they are on so tight.
I'm running the Fosi straight into a pair of Yamaha NS-6490 bookshelf speakers, some real dinosaurs from Radio Shack! But they sound awesome.
I also ordered some banana plugs and may or may not use them, but at any rate click this link for the ones I bought: Parts Express has some high-quality ones for reasonable cost. If you order them make sure to get 4! I sorta not-too-brightly ordered just 2, then realized, duh, I need 4...
This is a super versatile setup now. I use a very basic Panasonic MP3 player with BT, which was easy to connect. But, as you would expect with Bluetooth, you probably get better sound with a wire, so...
To plug in the MP3 I have a cable with mini-jack on one end and 2 RCAs on the other. Just plug the mini into the MP3 and the RCAs into the back of the Fosi, and it sounds great. You DO need to play with the volume on both units to get a good balance. I found that setting the MP3 at about 47 (the volume goes up to 60 on this unit) gave me a great range on the Fosi--99% of the time I have it set very very low for background music while I work, but if I turn it up to about 80% it will get pretty loud--watch the meter--just want the needle to bounce up into the red on the really loud parts.
Next thing will be to try will be running the Fosi into the Harman-Kardon. This will require a cable that is mini-jack on one end and two bare wires on the other--cuz the old HK just has screw-type connectors on the back--so I'll plug the mini into the pre-out on the back of the Fosi and attach the two bare wires to the AUX inputs on the back of the HK. This will effectively make the Fosi a pre-amp with BT for the HK. So I'll get the BT capability and signal boost from the Fosi, a line-level signal out to the HK, and that will give me the HK circuitry's vintage transistor (not tube) sound as well as a lot more EQ control and volume/power. I'll set the Fosi EQ to the center and let the HK do all the tone shaping. I suspect it will also be an order of magnitude louder without distortion, but we'll see. Also will need to feel out the best gain-staging balance between the Fosi and the HK volume controls.
Anyway super happy with the Fosi. I owe one of my kids for introducing me to the Fosi brand. Those youngsters know things.
a
Paul (Canada)
Perfect for my VO Studio PC
I'm a voice actor, and when I don't work with headphones, I need the sound in my space to fully represent what's playing through them. I have to hear the quiet things, the loud things, and every frequency in between. The MC101 does that and then some.
I have a great set of Klipsch speakers that I've been wanting to use with my PC, and this amplifier fits the bill perfectly. Bass and Tone adjustment, super clean sound, and all the range to make these great speakers shine.
I was going to buy a pair of monitor speakers, but I didn't like the notion of having to fiddle with the back of the speaker to adjust things. Plus, the flexibility of being able to use any speakers I want, and that gorgeous VU meter on the front... this is the ticket.
The Bluetooth input is a nice extra touch. The price and features and build quality were exactly what I needed. Thanks!
Paul (Canada)
Alex (Austria)
Really nice small amp
I initially tried the BT20 Pro amp and had to return it after realizing how not user friendly is the switch between Bluetooth and RCS inputs is. The MC101 is a general step forward in this regard! Is has simple 3 positions switch that just works as expected. I didn't buy specifically for the UV meter, but it would be nice if it had the sensitivity tuning. I tried the MC101 with both pairs of my speakers (vintage Summit HB901 and newer Canton LE107) and the VU meter doesn't move at all.
Alex (Austria)
J.D. (United States)
ANOTHER PART OF MY HIFI SYSTEM
I fondly remember warm tubes glowing. Anolog meters dancing left and right. Another set racing up and down. The lights flickering and relays clicking. This takes me back. Made me buy the GR70. Tubes is what I was taught in the Navy. Digital was gaining and the future. But try to get megawatts out of anything at that time not utilizing tubes, even traveling wave tubes (TWT), YOU OLD TECHS LEAVE THAT ALONE. IT'S AN EASTER EGG. SMILE AND REMINISCE.
J.
I'm new to the audio world. Never really heard warmth in a song. Now I get it.
J.D.
Sudhir (Qatar)
An amp for a small listening room
its not a high power amplifier as they advertised.
Sudhir (Qatar)
Anonymous (United Kingdom)
Great Product
Worked as intended.
Great Product
Worked as intended.
P (India)
Best Amplifiers Out There
One of the finest, most budget friendly
P (India)
