Key Parameters
Signal-to-Noise Ratio≥103dB;
Noise Floor: 64uV;
Crosstalk: 95dB
Mode Indicator
RCA mode: steady red light;
Bluetooth Connectivity
Bluetooth Range: ≥10m
Bluetooth Version: 5.1
Bluetooth Name: Fosi Audio P3
Bluetooth Reset
Preamp+Headphone Amp
DC 12V/1.5A
≤0.02%
≥103dB
From $119.99
DAC+Headphone Amp
DC 12V/1.5A
RCA, 3.5mm Headphone Jack
≥103dB
Fosi Audio P4 Mini Preamp with 3 RCA Inputs, EQ/Bypass, Treble & Bass Tone Control with Remote Control - Fosi Audio
From $99.99
Preamp
DC 12V/1.5A
RCA x3
RCA, Pre-Out
≤ 0.003%
From $179.99
DAC Preamp
DC 12V/1.5A
XLR, RCA
<0.00008%
≥126dB
Fosi Audio SK01 Headphone Amplifier & Preamplifier - Fosi Audio
Headphone Amp+Preamp
3.5mm Line In
≤ 0.001%
Based on 61 reviews
82%
(50)
13%
(8)
3%
Watt Phuket
Product not Proper QC
One of Vacuum Tube not working, must find on local shop for replacement
Jørgen Davidsen
MaR Gusto
P3 tube preamp
Everything fine...
Mark F.
Great preamp
Simon Manners
Great for my Van Audio
I previously installed an Ecoxgear SE26 on the rear tailgate of my van. Used Bluetooth from my phone to stream the music. The sound was very difficult to get right and just didn’t sound very good. Decided to pop in this little preamp and wow what a difference. This little unit turned a very mediocre system into a fanatastic sounding one. The tone controls help tune the sound to the ambient noise of the van when travelling and adds such great depth and warmth overall. You should 100% use one of these as in the scheme of things it’s not an expensive addition and punches well above its weight. I just wired the power of the preamp into my 12v battery system in the van which uses a Victron DC to DC converter for stable voltage control. Thanks Fosi!
