Key Parameters
Signal-to-Noise Ratio≥103dB;
Noise Floor: 64uV;
Crosstalk: 95dB
Mode Indicator
RCA mode: steady red light;
Bluetooth Connectivity
Bluetooth Range: ≥10m
Bluetooth Version: 5.1
Bluetooth Name: Fosi Audio P3
Bluetooth Reset
  • True Tube Amplification: The preamp circuit elevates the voltage to 54V, ensuring the tubes work to their full potential, delivering a warm and rich experience. The unique preamplification technology delivers pure audio signals, faithfully reproducing crisp high tones, full midrange richness, and deep, rhythmic bass.
  • What You'll Get: Fosi Audio P3 Tube Preamplifier x1, User Manual x1,  Vacuum Tube x2, 12V/1.5A Power Supply x1, a 24-month worry-free warranty and responsive customer service.
  • RMS Power: 250mw @16Ω;150mw @32Ω;32mw @250Ω;20mW @300Ω
  • Noise Floor: 64uV
  • Input Mode: Bluetooth, RCA
  • Output Mode: RCA, 3.5mm Headphone Jack, AUX Out
  • Frequency Range: 20Hz-20kHz(±1dB)
  • Dynamic Range: 104dB
  • THD: ≤0.02%
  • SNR: ≥103dB
  • Crosstalk: 95dB
  • Bluetooth Chip: QCC3031
  • Bluetooth Version: 5.1
  • Bluetooth Range: ≥10m
  • Power Input DC: 12V/1.5A~3A;
  • 5654W Vacuum Tube x 1
  • 12V/1.5A Power Supply x 1
  • User’s Manual x 1
Preamp+Headphone Amp
DC 12V/1.5A
≤0.02%
≥103dB
From $119.99
DAC+Headphone Amp
DC 12V/1.5A
≥103dB
Fosi Audio P4 Mini Preamplifier - Fosi Audio
From $99.99
Preamp
DC 12V/1.5A
RCA x3
RCA, Pre-Out
≤ 0.003%
From $179.99
DAC Preamp
DC 12V/1.5A
XLR, RCA
<0.00008%
≥126dB
Fosi Audio SK01 Headphone Amplifier Preamp - Fosi Audio
Headphone Amp+Preamp
3.5mm Line In
≤ 0.001%
Customers praised this tube preamplifier for "amazing clarity" and "warm, natural sound." Many noted excellent value, versatile Bluetooth and RCA inputs, and effective tone controls. Pairs well with amplifiers. Some reported tubes difficult to insert, one vacuum tube failure, minor Bluetooth range issues, and slight clarity loss. Overall highly recommended for budget desktop audio setups.
  • 5 stars: 63 (83%)
  • 4 stars: 9 (12%)
  • 3 stars: 3 (4%)
  • 1 star: 1 (1%)
DGJ (The Netherlands)
Nice tube amp
It's a nice tube preamp. I use it for streaming music to my active S3000MKII speakers, the sound has now a warm tone. The only problem I have is that the bass button center is not 100% in the center, but it's more 98% in the center.
g
giannisPavlo (Greece)
P3 preamp+ZA3 AMP+arylic streamer
Thanks FOSI for this amazing sound..
Warren (United States)
Almost too good to be true
Wow, it is exactly, no better than what I hoped for. (Since it also is a Bluetooth receiver) I was looking at a Marantz tubed preamp KIT for $150, they were going to charge me $75 for shipping and then I’d have to assemble it! Oh and it sounds great and gives me an RCA in a case I ever get a CD transport. I have thousands of them but honestly only listen to my phone . Thanx you I highly recommend anything y’all make and sell.
Francois (South Africa)
P3 xmas gift...
Shane (United Kingdom)
Simply amazing preamp with a mind blowing sound system
Thanks to FOSI Audio staff for all your help creating my dream setup. I was advised to add the P3 PreAmp to my second BT30D Pro, which runs my rear speakers and is fed by the pre-out of my first BT30D Pro. The difference is night and day; everything sounds balanced, and the quality is amazing, when we are listening to music it’s like we have a live band playing in our front room. Everything is so crystal clear.
My front speakers as mentioned also powered by a BT30D Pro, with the input coming from my TV’s optical port via a DAC, then through a CYP delay unit to synchronize all the speakers. This setup allows me to run my soundbar, which has two fronts, two rears, and a sub, alongside the two BT30D Pros. Altogether, I have 8 speakers, 4 subs, 2 BT30D Pro Amps, and a P3 PreAmp connected and synced to my TV.
The setup from here involves two passive speakers and a passive sub connected to my first BT30D Pro. The pre-out goes into my P3 PreAmp, then into my second BT30D Pro, which runs two passive speakers and a powered sub in my front room. The passive sub output goes to a sub in the room directly above to block out noises from my noisy neighbours. They have an industrial combined dryer/washer attached to our front room wall. After kindly asking them to move it and being told to go stand in the garden while it's on (tricky when it's on nearly all day until 9 pm), I devised this setup to completely block their noise. Now we can enjoy watching TV again.
The system as a whole exceeds my expectations, and I am thrilled I chose FOSI Audio for my amplification and pre-amplification needs. Having previously DJed with Electro Voice ZLX-15P’s, I can confidently say the FOSI Amps offer far higher quality sound. You can hear every note, and they definitely blow the cobwebs away. If we turn them up, you can feel the wind from the speakers as the FOSI amps are incredibly responsive. The clarity is unparalleled. I am extremely pleased, and I had to write this review to thank the FOSI staff team. You are amazing, and I wish you all a very Happy New Year.
I've also made a short video, which I sent to FOSI Audio, showcasing how my setup turned out. They've told me it will be added to the FOSI Audios shorts section on their YouTube channel, which is an honor. The video is too big to upload here, but I'll share some pictures. Thanks again from a very satisfied customer who will definitely be back.
Anonymous (Serbia)
P3
I have been using the Fossey P3 Preamplifier for a few months now and I am very happy with it. I have connected 2 systems and 2 pairs of speakers to it via the LC 30 VU meter.
I use it occasionally when I listen to vinyl LP BOX X2.
I expect Fosey to release a Preamplifier with a turntable input and an RCA input for other devices so that I don't have to use 2 preamplifiers...
Robert (United States)
Fosi P3 Tube Pre-Amp
If you're into tube rolling, this little miracle is hard to beat. Removable tube rings make swapping tubes easy. RCA & Bluetooth input. I bought two, one as a nightstand headphone amp & one paired with four Fosi V3 Monoblocks to bi-amp my Wharfedale 85's.
Nola (New Zealand)
LOVE these amps!
Love these and have bought four now! One for my car and one for every room!
Zoltán (Hungary)
the really needed v3 update
My V3 amp was love at first hearing, but every now and then I felt the need to add a little more bass or treble depending on what I was hearing. P3 is very good for this. The tube was a plus for the sound nature, which I can't describe, but I love it. Bluetooth is much better than other cheaper adapters. The design together with v3 is very good. It's just that the updated orange button on the P3 is a little bigger than the original black one, and as I turn it, it scratched into the housing, it's really only 1-2 tenths of a millimeter from the outer diameter, but it should be smaller by that . Due to this small mechanical deficiency, it is uncomfortable to adjust the volume on the preamplifier, so I might anodize the original to the same color, because the design requires it.
Andy (United States)
A plus to all that makes this possible.
Amazing clarity,
BriTon123 (Canada)
Stephen
Great solution to my turntable connection issue. Very noise free audio.
Anonymous (United Kingdom)
Born as a natural partner for V3
A very good preamp, good channel separation, warm and natural sound reproduced and could hear no hiss from it.
James (United States)
Fosi AUDIO P3
Cute. Does what it is supposed to do. Fair price. Difficult to insert tubes. Overall satisfied.
Kendi (United States)
Fosi Audio P3
The Fosi Audio P3 is an exceptional budget tube preamp that brings genuine analog warmth to any desktop audio setup. Paired with a mini power amp like the Fosi V3, it creates a visually striking and musically engaging stack.
Key Highlights
Alvaro (United States)
Fosi audio P3 tube preamplifier
This is an excellent component , well build and sound excellent conected to fosi amplifier . I enjoy the clean sound and highly recommend this pre amp
Henry (United States)
Awesome love it
Great device looks great and works very well .
Tony (United States)
Good sound and terrific value.
I use my P3 to feed Bluetooth signals from my phone, and line inputs from an Amazon Echo, into my home sound system. It’s easy to connect, stable, and sounds good. Meets my expectations completely.
JP (United States)
Love my tube amp
Got it a couple days go, I love it. Works great with the V3 amp I got in a bundle.
Eric (United States)
Great sound
Very clean sounding
David (United States)
Great things come in small packages
Wonderful little pre-amp! Very quiet noise floor, and does not appear to inject problems of any kind. I am not sensing a lot of harmonics from the tubes. But they are being used as buffers, so that is to be expected. The bass and treble adjustment envelopes/curves feel very good. Honestly, Fosi are creating great value for dollar and the P3 is a great example of that.
Watt (Thailand)
Product not Proper QC
One of Vacuum Tube not working, must find on local shop for replacement
Jørgen (Greenland)
Fosi Audio P3 Tube Preamp with Bluetooth aptX LL HD Bass and Treble Tone Controls
MaR (Singapore)
P3 tube preamp
Everything fine...
