Product Highlights
Amplifier Chip
Power Output
THD
Product Highlights
Amplifier Chip
Power Output
THD
Limited-time offer: Free orange knobs or banana plugs
                - TPA3255 Chip, 88dB SINAD
 - Full-Body Heatsink Cooling
 - Pre-out with Volume Control
Born for HiFi Enthusiasts
- Max Power Output: 300Wx2@4Ω
 - SINAD: 88dB | SNR: ≥110dB
Innovative Cooling System Design: Fosi Audio has made significant breakthroughs in the thermal design of the V3 amplifier. There are vents on the top and bottom of the case, and the chip heatsink is attached to the case to realize the whole-body heatsink design, enhancing air circulation and heat dissipation. Its special design allows for extended usage without compromising performance or causing any detrimental effects.
Hi-End Sound Quality: With Texas Instruments' TPA3255 Class-D power amplifier chip,the V3 amplifier achieves exceptional power efficiency. With audiophile-grade materials, such as Sumida professional audio inductors, NCC high-capacity filter capacitors, German WIMA Output Capacitors, Japanese ELNA Capacitors, etc. Those high-quality components allow V3 to maintain very high stability even under high-power working conditions. With the V3, you can truly have an almost distortion-free music playback experience.
Customizable Sound Signature: The V3 amplifier features replaceable op-amp chips, there're two plug-ins NE5532 Op-Amps can be replaced by SS3602, MUSES02, OPA2134PA Op-Amps etc.enabling users to experiment and achieve their preferred sound signature by swapping different op-amp chips.
Compact and Versatile: Despite its compact size, the V3 amplifier has the capability to drive passive speakers effectively, making it a versatile choice to turntable amplifiers, CD player, and DVD for creating a complete HiFi system.
- Chip Set: TI TPA3255
 - Output Power: 300Wx2 @4Ω
 - Terminating Impedance: 2-8Ω
 - Input Mode: RCA
 - SINAD: 88dB
 - THD: 0.003%
 - SNR: ≥110dB
 - DC Input Range: 24-48V
- V3 Power Amplifier x 1
 - User’s Manual x 1
