NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
From $109.99
300W@4Ω
RCA, XLR, ¼”TRS
Speaker Output
<0.006%
≥123dB
From $109.99
2.0 CH Amp
RCA, XLR, ¼”TRS
Speaker Output, Sub-Out
<0.006%
≥106dB
From $69.99
2.0 CH Amp
Passive Speakers, Pre-Out
≥ 108dB
From $89.99
Subwoofer Amp/MoxAmp
200W
≤0.03%
≥ 106dB
4-8Ω
32V/5A
Based on 110 reviews
82%
(90)
15%
(16)
4%
Anonymous
The only amp I’ll buy these days
Depending on the features you need, something else might work better but I just need clean, mono amps with no processing or extra features other than the auto on, which this has. I use them with my AVR and they work flawlessly. My speakers, AVR and ears are all happier every time I add one of these Fosi V3 Monos to the equation.
Abdullah Hamad
This little amp does wonders
The Fosi V3 Monoblock amplifier may be small in size, but it delivers power and clarity well beyond expectations. For the price and size, the Fosi V3 Monoblock is nothing short of remarkable. When paired properly, it delivers high-end sound with minimal distortion and rock-solid performance. It's proof that you don't need a massive amp to experience great audio
Outof Into
These Fosi v3 monoblocks are exceptional
I bought 4 of these Fosi v3 monoblocks with 2 x 48volt/10amp power supply units. They are being used to drive Tannoy XT8F revolution tower speakers in a vertical mono/bi-amp mode ( i.e. each speaker is connected to 2 monoblocks with a shared PSU ).
After an initial 24 hour burn in, they opened up to produce a wonderfully transparent, dynamic and powerful sound. The treble is clean without edge or grain, the midrange is very clear with excellent low level detail resolution and the bass is well controlled, defined, extended and surprisingly hard hitting. The overall tonal balance is quite neutral with just a hint of treble forwardness.
The Fosi v3 small form factor, belies its capability when producing a very large soundstage with terrific focus on, and the space between, the musical elements within it. Plus the stereo imagery is precise with good centre focus, coherence and decent depth.
I was originally sceptical about the V3 mnbks when I heard, read and saw ( on You tube ) the rave reviews about them. Now I have confirmed for myself, their exceptional performance for the money.
Compared to my 2 other, much more expensive power amps, from Marantz and Emotiva, they more than hold their own.
Highly recommended.
Additional information:- Everything said about the v3 monoblocks remains the same, ( if anything they're even better sounding than when they were first reviewed, due to slightly less treble forwardness ). However they do become hot during use.
Therefore I recommend using a low noise fan ( if you can't put them on/in a well ventilated shelf/cabinet ). DON'T stack them on top of each other without adding feet to separate them.
Alex
Donnie L
V3 monos
