NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
  • Channel : 1.0
  • Input : RCA, XLR, ¼" TRS
  • SNR : ≥123dB
  • Dynamic Range : ≥123dB
  • THD : <0.006%
  • Terminal Impedance : 2-8Ω
  • Standard PSU : 48V/5A
From $109.99
300W@4Ω
RCA, XLR, ¼”TRS
Speaker Output
<0.006%
≥123dB
From $109.99
2.0 CH Amp
RCA, XLR, ¼”TRS
Speaker Output, Sub-Out
<0.006%
≥106dB
From $69.99
2.0 CH Amp
Passive Speakers, Pre-Out
≥ 108dB
From $89.99
Subwoofer Amp/MoxAmp
200W
≤0.03%
≥ 106dB
4-8Ω
32V/5A
Based on 124 reviews
83%
(103)
14%
(17)
3%
DocHouse
Hot Stuff
Hot stuff but very cool sound
Leonidas K.
Fosi Audio V3 Mono Monoblock Power Amp
I bought two of these amps a couple of months ago, to use with a Rega planar 3 turntable as a main source.
The connection is via an X5 phone preamp and the ZP3 preamp.
Previously the turntable was connected to an all in one old Marantz amp, via the X5.
Compared to the previous setup, with the ZP3 & V3s the audio is significantly improved. There is much more clarity, a wider sound stage and better distinction between the instruments.
My current speakers are easy to drive, so it was very easy load for the V3s, and the volume could easily be set much higher that what was enough for the space the system is in.
As many other people have said, the amps get quite hot, and though I could put mu hand on them, I definitely would not want to keep it on for a long time. I do not know if it will be a problem in the long run, but so far it does not seem to have affected the performance of the amps at all.
I tried connecting to the preamp via RCA and XLR, I cannon say that I noticed a significant difference, but I did not have any noise/interference issues with the RCAs to begin with.
Jess Uhl
ל
ליאור כהן
Sickk
Sickk
Philip Baarendse
Perfect mono amp for a desktop speaker
The Fosi V3 Mono amplifier is perfect for my use case, of powering a desktop speaker. I like the small size, minimalist switches, and auto-standby mode.
