NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
From $109.99
300W@4Ω
RCA, XLR, ¼”TRS
Speaker Output
<0.006%
≥123dB
From $109.99
2.0 CH Amp
RCA, XLR, ¼”TRS
Speaker Output, Sub-Out
<0.006%
≥106dB
From $69.99
2.0 CH Amp
Passive Speakers, Pre-Out
≥ 108dB
From $89.99
Subwoofer Amp/MoxAmp
200W
≤0.03%
≥ 106dB
4-8Ω
32V/5A
Based on 113 reviews
82%
(93)
14%
(16)
4%
James Chychota
Impressive Sound — Incredible Value in a Small Package”
The Fosi V3 Mono amps are genuinely impressive. I’ve paired them with my 4-ohm DIY Scan-Speak MTM speakers, and they deliver clean, detailed sound with excellent control and zero background noise. Imaging is tight, and dynamics are punchy — these little amps can really drive.
They’re running off two separate 48V/5A power supplies with USB-powered cooling fans. Even under heavy use, they stay cool and stable. Compared directly with my ICEpower and large Class AB amps, the V3 Monos hold their own — and for a fraction of the size and cost.
Only minor complaint: the LED ring brightness is inconsistent between the two amps. One is noticeably brighter than the other. It doesn’t affect performance at all, but it’s a cosmetic mismatch worth noting for perfectionists.
Overall, though, I’m thrilled with the sound and value. These are keepers.
Michael Dominguez
Andy Clandillon
Fosi Audio V3 Monos - first impressions
Hi all,
Got a set of four V3 Mons too bi-amp a pair of Heco floorstanders. The amps are just about broken in, and the resulting sound is open, very well staged, excellently balanced tonally and with great responses.
All in all, thoroughly recommended!
Anonymous
The only amp I’ll buy these days
Depending on the features you need, something else might work better but I just need clean, mono amps with no processing or extra features other than the auto on, which this has. I use them with my AVR and they work flawlessly. My speakers, AVR and ears are all happier every time I add one of these Fosi V3 Monos to the equation.
Abdullah Hamad
This little amp does wonders
The Fosi V3 Monoblock amplifier may be small in size, but it delivers power and clarity well beyond expectations. For the price and size, the Fosi V3 Monoblock is nothing short of remarkable. When paired properly, it delivers high-end sound with minimal distortion and rock-solid performance. It's proof that you don't need a massive amp to experience great audio
