NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
From $109.99
300W@4Ω
RCA, XLR, ¼”TRS
Speaker Output
<0.006%
≥123dB
From $109.99
2.0 CH Amp
RCA, XLR, ¼”TRS
Speaker Output, Sub-Out
<0.006%
≥106dB
From $69.99
2.0 CH Amp
Passive Speakers, Pre-Out
≥ 108dB
From $89.99
Subwoofer Amp/MoxAmp
200W
≤0.03%
≥ 106dB
4-8Ω
32V/5A
Based on 117 reviews
82%
(96)
15%
(17)
3%
Keith
Problem solved.
Jon Kidd
New V3 amps mean I don't need new speakers!
I received the V3 monoblock amps earlier today, and have spent the last hour playing some Beethoven 7th, Rush Hemispheres, Dixieland Jazz, Wide Mouth Mason blues. They have revived my old Morrison speakers, which never delivered decent bass until the V3's were hooked up. Nice stereo imaging, too!
Michał Bednarek
True brutal power!
I'm very pleased of purchase of these monoblocks. They deliver enough power to my Quadral Titans V5. Sound is pure and perfect.
There is only one disadvantage which is heat. They get pretty warm even at low volume.
j
jeff julian
Class D Mono blocks with individual 48v 10amp max. power supplys.
For the price you cannot go wrong especially if you have a good pre amp that compliments them. Deep spacious and wide sound stage. I couldn't believe the bass you get.
James Chychota
Impressive Sound — Incredible Value in a Small Package”
The Fosi V3 Mono amps are genuinely impressive. I’ve paired them with my 4-ohm DIY Scan-Speak MTM speakers, and they deliver clean, detailed sound with excellent control and zero background noise. Imaging is tight, and dynamics are punchy — these little amps can really drive.
They’re running off two separate 48V/5A power supplies with USB-powered cooling fans. Even under heavy use, they stay cool and stable. Compared directly with my ICEpower and large Class AB amps, the V3 Monos hold their own — and for a fraction of the size and cost.
Only minor complaint: the LED ring brightness is inconsistent between the two amps. One is noticeably brighter than the other. It doesn’t affect performance at all, but it’s a cosmetic mismatch worth noting for perfectionists.
Overall, though, I’m thrilled with the sound and value. These are keepers.
