12V Trigger Sync Interface
Logarithmic Potentiometer
From $109.99
ZA3 Balanced Stereo Amplifier
2.0 CH Amp
RCA, XLR, ¼”TRS
Passive SPK +Sub-out
<0.006%
≥106dB
From $109.99
300W@4Ω
RCA, XLR, ¼”TRS
Speaker Output
<0.006%
≥123dB
TB10D Stereo Audio Amplifier
2.0 Ch Amp
300W x2
Passive Speakers
≤ 0.3%
≥ 90dB
From $69.99
2.0 Ch Amp
Passive Speakers, Pre-Out
Based on 266 reviews
88%
(235)
9%
(23)
Michael Armstrong
Fosi Audio ZA3 Amplifier
I was impressed with the sound quality of the system I built with Fosi Audio gear. I'm using the ZD3 Dac running into the ZA3 amplifier ran in stereo and two V3 mono blocks for a 4 channel outdoor system in my pole Barn. Sounds great!
Bill Hiltz
ZA3 compares favorably to 40lb AB legacy amplifier
I am a very fussy old audiophile. My reference solid-state power amp is a dual mono Aragon and I also have been using a high quality Cayin tube amplifier with Focal towers. The ZA3 comes very close to both of them in terms of detail and ability to drive any speakers I throw at them. The tube amplifier has a different presentation so it is not quite an apples to apples comparison. I do find the soundstage and overall smoothness of the ZA3 improves inserting a preamp in the chain. Incredible value like every other Fosi Audio product I have. Do not buy another expensive solid state audiophile amp without auditioning one of the Fosi amps. You will get much better bang for the buck by upgrading your speakers where you will not have to struggle to listen for minute differences.
Louie Canillas
Great amp
Upgraded from a douk audio ns-13g. Cant believe the sound difference my Polk es10 pump out. Highly recommend. Perfect companion to a WiiM ultra
j
javier astorga
Buena relacion precio producto
Lo compare contra un mc250 y me sorprendi
Oscar
Buena relación calidad - precio
Por el tamaño y la potencia que puede generar es excelente para lugares con poco espacio, no se calienta mucho, pero si se recomienda tenerlo en un lugar ventilado, la opción del disparador (trigger) permite que se una con preamplificadores y trabaje muy bien, si no quieres gastar de más, no te preocupes por usar las entradas XLR, con las RCA tendrás más que suficiente.
