  • 2021 NEW MODEL: The updated version for BOX X2. Next-generation phono preamp for unrivaled sound quality.
  • MM Phono Preamplifier: The BOX X4 phono preamp supports 3.5MM AUX and MM turntable input, converting phono signals to Line Level signals with low-noise integrated circuits and high-quality components to remove low-frequency noise ensure clear sound quality. Designed with a grounding post to protect your turntable.
  • Tube Headphone Amplifier & Preamplifier: The BOX X4 is designed with a 3.5MM AUX headphone and RCA output, highly useful beyond imagination.
  • Applicable Vacuum Tube Model: 5654W/6K4/6J1/6J4/GE5654/6AK5/66*In vacuum tubes, etc. You can replace the vacuum tubes to DIY your stereo system. Different tubes with different sounds.
  • What You Get: BOX X4 phono preamp, DC 12V power supply, user manual, our worry-free 24-month warranty, and friendly customer service.
Phono Preamp & Headphone Amplifier with JAN 5654W Vacuum Tubes for MM Turntable Phonograph Preamplifier for Record Player with Volume Bass Treble Control Hi-Fi Pre Amp Fosi Audio Box X4
Model BOX X4
Applicable headphone types 16 Ω
Input Mode MM turntable + 3.5mm AUX
Output Mode RCA + 3.5mm headphone output
Output Active(powered) speakers, Amplifier, Headphones
THD ≤ 0.1%
SNR ≥ 70dB
Device Dimension 4.72 x 3.97 x 1.37 inches
DC Input Range 12V
Input Voltage Range AC 110V - 240V
Output Voltage Level 1kHz and 650mV
Power Supply 12V 1.5A
BOX X4 phono preamp x 1
Vacuum Tubes x 2
DC 12V power supply x 1
User's Manual x 1
