  •  Hi-Fi Amp with Clean Sound Quality: Fosi Audio M03 subwoofer amp adopts the Instruments TPA3255D2 chip, High Efficient Power Output Up to 200Watt, providing 150 watts RMS into 4-ohm loads or 120watts to 8-ohm loads. Great amplifier to driver any bookshelf speaker or subwoofer;
  • Subwoofer amplifier and Full-Frequency Mono Amp: Switch to PBTL, it's a Full-Frequency Mono amp for driving passive speakers and powered subwoofer. Switch to SUB, it's a subwoofer amplifier for diving passive and powered subwoofers;
  • Mini Compact but Powerful: Built-in low pass filter for 20-300Hz subwoofers with SUB frequency control, small simple compact design but practical and powerful;
  • Home Hi-Fi amplifier: Exclusively designed for the customers who pursue HiFi sound; MAX Power Output:200Watt. Note: The package comes with a 32V/5A power supply, you need a more powerful power supply to get the MAX power output;
Subwoofer Amplifier 200 Watt Mini Mono Audio Amp Full-Frequency and Sub Bass Switchable Amplifier One Channel Home Theater Single Power Subwoofer Amp Fosi Audio M03
    Model M03
    RMS Power Output: RMS 200watt at 4ohm, RMS 100watt at 8ohm
    Terminating Impedance 4-8Ω
    Input Sensitivity ≤ 0.2mV
    Full Frequency Response Range 20Hz-20KHz(± 3db)
    Bass Frequency Range 20-200Hz
    THD ≤0.03%
    SNR ≥ 106dB
    DC Input Range 24-48V
    Power Supply 32V 5A
    Fosi Audio M03 Amplifier x 1
    32V 5A Power Adaptor x 1
      Compare with similar items
      Based on 8 reviews
      88%
      (7)
      13%
      SHIVA SHANKER PRASAD
      PERFECT SUBWOOFER APM FOR MY 180W PASSIVE SUBWOOFER
      This subwoofer amp has brougth life to my 2005 vintage Sony make 180watt passive subwoofer . I am using M0-3 Amp as Subwoofer amp. Connected from subwoofer output of ZA-3 AMP . This setup is working absolutely fine. I am happy with this setup.
      Rick
      It works
      Good product, prompt shipment. Excellent tech support.
      Cory Martin
      Excellent small powerful sub amp
      I have an older Infinity 12" powered sub that it's internal amplifier stopped working. This little Fosi amp I am now using to replace the broken one. Sound and output of the sub is a great pairing for this sub and reasonable cost compared to a new plate amp. I was suprised how well it controlls the 12" sub with no distortion at typical listening levels.
      Charlie Morgan
      Great replacement for failed plate amp
      When the plate amp went out on my old JBL E250P subwoofer (12" ported) I first considered a new Express Parts plate amp, but that would have required major butchery of the cabinet. Then I found out about mini-amps and read great things about Fosi. I was skeptical that a small amp could power a fairly large subwoofer. But after looking at the Fosi web cite I decided to give the M03 a shot. When I played the opening couple minutes of Oppeheimer (bomb blast) I knew I had made the right choice. The walls shook and I had goose bumps. My only nit--I wish the little amp had auto turn on and timed turn off.
      p
      peter joyce
      quite the surprise!
      Wasn't sure what to expect with this little amp, but it really surprised. Using it to power a 8in Yamaha 6ohm passive sub, it put out impressive base that was really well controlled. The crossover worked a treat and I used the volume to set a 'master' gain for the sub as the Fosi ZA3 commanded the system volume.
      Overall this was a surprise package in a small system. Driving an 18" in a club maybe not, but in a moderate room with a reasonable passive sub really really good, clean tight base at impressive volumes!
      Really my only quibble is the form factor, its really tight for realestate on the back, my interconnects were large (overkill for the set up) and the speaker binding posts are small, I used banana plugs as my stub fingers would struggle to get wires in there!
      (note: I have not used this amp in a full range configuration)
