The High Quality Operational Amplifier Chip Burson V7, SparkoS Labs SS3602MUSES02 and OPA2134PA can replace the ZA3BT20A PRO, and V3's operational amplifiers and can create different sound quality, providing you with a versatile Hi-Fi listening experience.
SS3602
Based on 102 reviews
81%
(83)
12%
(12)
3%
4%
j
jung koo whan
SparkoS Labs SS3602, Burson V7, MUSES02, OPA2134PA
Hans Oldenburg
Goede tonen
Het geluid zweeft door de kamer
Scott Porter
opamps work
sparks are great
Logli Massimo
Tutto ok
Gli Op Amp Sparkos fanno la differenza e si sente.
Scott Lowell
There best opamp available= Sparkos
I have listened to the TI, Burson Musa and OPA op amps available to install in the FOSI.
The USA made Sparkos is the clear and obvious winner across the board. It has better transients, cleaner detail and obvious power. The others are either almost as good, or not even close to as good.
There is no point in the others for me. Sparkos….period.
