Precio habitual
$79.99 USD
Precio de venta
$79.99 USD
Precio habitual
$79.99 USD
  • Authentic Tube Amplification
  • Qualcomm aptX LL Bluetooth
  • Treble & Bass Adjustment
  • Ideal Partner to V3 Amp
RMS Power: 250mw @16Ω; 150mw @32Ω; 32mw @250Ω; 20mW @300Ω
Headphone Impedance: 16-300Ω; SNR: ≥103dB; THD: ≤ 0.02%
Input: Bluetooth 5.1/RCA; Output: RCA/AUX/3.5mm headphone jack; Dynamic Range: 104dB; Frequency Response: 20Hz-20kHz(±1dB)
Headphone Output
RCA Input
Partner to V3
Desktop Preamp
Bass and Treble Controls
Audiophile-Grade Capacitors
Built-in quality Japanese ELNA caps for outstanding performance.
Qualcomm aptX Bluetooth QCC3031 Chip
Supports multiple codecs formats: SBC/AAC/aptX/aptX HD/aptX LL.
Logarithmic Potentiometer
Effortless Insertion & Removal
Suitable for 7-pin vacuum tubes. Please align each pinhole before installation.
DIY Your Stereo System
Applicable Vacuum Tube Model: 6K4/6J1/6J4/GE5654/6AK5, etc. vacuum tubes.
5654W Vacuum Tubes
Experience the unique charm from vacuum tubes.
The Synthesis of Tech and Nature
Embracing technology, staying close to nature, and maintaining global climate awareness.
Exquisite Craftsmanship
Utilizing CNC integrated molding, precise sandblasting, and meticulous detailing.
Key Parameters
Signal-to-Noise Ratio≥103dB; Noise Floor: 64uV; Crosstalk: 95dB
Mode Indicator
RCA mode: steady red light; Bluetooth pairing mode: blue light flashing; Bluetooth connection built: steady blue light.
Bluetooth Connectivity
Bluetooth Range: ≥10m Bluetooth Version: 5.1 Bluetooth Name: Fosi Audio P3
Bluetooth Reset
  • True Tube Amplification: The preamp circuit elevates the voltage to 54V, ensuring the tubes work to their full potential, delivering a warm and rich experience. The unique preamplification technology delivers pure audio signals, faithfully reproducing crisp high tones, full midrange richness, and deep, rhythmic bass. (Important Tips: Remove the copper rings for effortless installation of the tubes on the P3.)
  • What You'll Get: Fosi Audio P3 Tube Preamplifier x1, User Manual x1, 5654W Vacuum Tube x2, 12V/1.5A Power Supply x1, a 24-month worry-free warranty and responsive customer service.
RMS Power: 250mw @16Ω;150mw @32Ω;32mw @250Ω;20mW @300Ω
Noise Floor: 64uV
Input Mode: Bluetooth, RCA
Output Mode: RCA, 3.5mm Headphone Jack, AUX Out
Frequency Range: 20Hz-20kHz(±1dB)
THD: ≤0.02%
SNR: ≥103dB
Crosstalk: 95dB
Bluetooth Chip: QCC3031
Bluetooth Codecs: SBC/AAC/aptX/aptX HD/aptX LL
Power Input DC: 12V/1.5A~3A;
  • 5654W Vacuum Tube x 1
  • 12V/1.5A Power Supply x 1
Based on 60 reviews
83%
(50)
13%
(8)
Jørgen Davidsen
MaR Gusto
P3 tube preamp
Everything fine...
Mark F.
Great preamp
Simon Manners
Great for my Van Audio
I previously installed an Ecoxgear SE26 on the rear tailgate of my van. Used Bluetooth from my phone to stream the music. The sound was very difficult to get right and just didn’t sound very good. Decided to pop in this little preamp and wow what a difference. This little unit turned a very mediocre system into a fanatastic sounding one. The tone controls help tune the sound to the ambient noise of the van when travelling and adds such great depth and warmth overall. You should 100% use one of these as in the scheme of things it’s not an expensive addition and punches well above its weight. I just wired the power of the preamp into my 12v battery system in the van which uses a Victron DC to DC converter for stable voltage control. Thanks Fosi!
Douglas Wiles
V3
This amp pounds. Well worth the money.
