The Compact Control Hub for
Your Home Audio System
The P4 is a mini preamp supporting three inputs, developed based on extensive feedback
from users worldwide after the launch of the V3 stereo amp.
We will continue to listen carefully, record your feedback promptly, and make efforts to turn your ideas and suggestions into reality.
I would pay $150 for a pre that had 2-3 RCA inputs a real sub out and with volume, bass and treble. -Northa40 from ASR
Now for this pre-amp, lโd be more impressed if it didnโt have tubes, and maybe more inputs. -Jim from ASR
SS preamp that would allow for multiple inputs, with a remote. -Joe Smith from ASR
If you want to make a real preamplifier, it should have at least 2-3 inputs. -Zek from ASR
It would be perfect if it had bypass and a remote... and actually worked properly. -TonyJZX from ASR
Anche in questo caso le prestazioni sono decisamente adeguate al prezzo e la comoditร del potenziometro motorizzato รจ una chicca da non sottovalutare.
The Fosi P4 surprises with incredibly low cost while providing features such as motorized volume control and excellent performance.
Easily connect up to three audio sources, with one-touch input switching for ultimate audio freedom
Not only provides a smoother volume adjustment experience, but also further reduces noise and distortion, delivering a purer soundscape for you
Bypass the tone control to enjoy the purest high-fidelity sound.
Match different output levels from audio sources for improved sound quality.
Expandable connection for a powered subwoofer.
Achieve personalized tuning with central detents for better sound customization.
Easily adjust the volume, switch sources, and control the tone without leaving your seat, enjoying a convenient audio experience
Metallic texture, compact and refined, with enhanced resistance to electromagnetic interference
With a harmonious and unified appearance, it elevates both the visual and audio experience of your sound system
Channel
2.0
RCA*3
RCA, Pre-out
โฅ 110dB
Dynamic Range
โฅ 110dB
โค 0.003%
Crosstalk
โฅ 105dB
Noise Floor
โค 9ฮผV
Tone Adjustment Gain
ยฑ12dB
Frequency Response
20Hz-20kHz(ยฑ0.1dB)
DC 12V/1.5A
Free Shipping
Money-Back Guarantee
30 Days Free Return
Quality Assurance Guarantee
