Why Audio Matters in FPS Games?
- Hear Footsteps Clearly
- Identify Enemy Direction
- Better Judge Distance
- Protect Your Hearing
Fast, Free Shipping
What Did the Creators Say After Playing?
Upgrade Your Gaming Audio. Win More
StepSense™ Tracks Enemies Beyond Your Vision
Detect & Boost Footsteps (3-9 dB) | 10 ms Ultra-Low Latency ||No Change to Gunfire/Explosions
Trained on extensive FPS audio data, StepSense™ is continuously reffined for higher accuracy and better game compatibility
Flagship Chipset
Reveal Fine Details with Ease
With audiophile-grade components, C3 reveals subtle details in game audio, adding depth and realism without altering the original sound design.
7.1 Spatial Audio
Battle Comes Alive
In games or movies that support multichannel output, such as Delta Force and Forza Horizon 5, enabling 7.1 audio delivers realistic distance cues and deep immersion.
Control Hub
Sound Presets for Immersion
Switch between presets or fine-tune your sound with EQ controls, all through a clean, browser-based interface, no software required.
All-Aluminum Alloy Chassis
Solid weight and premium feel, stays firmly inplace during ad
Compact Size
Clean and minimal, takes up little
desk space.
Intuitive Buttons and Sliders
Clear layout with tactile feedback for quick, no-look control.
Ergonomic 5°Angled Design
Angled for better visibility and more comfortable desktop operation.
Rich Connectivity & Controls
| Chipset | XMOS XU316 + CS43131 + TPA6120*2 |
| Maximum Sampling Rate | UAC 2.0:PCM 32-bit/384kHz; DSD256 UAC 1.0:PCM 16-bit/48kHz OPT:PCM 24-bit/192kHz COAX:PCM 24-bit/192kHz |
| Supported Headphone Impedence | 16-300Ω |
| Input | Coaxial, Optical, USB-C (Power & Data), 3.5mm Microphone |
| Output | 3.5mm Headphone, RCA |
| Firmware Update | USB-C Online Update |
| Input Voltage | DC 5V |
| PEQ Page Link | https://cc.fosiaudio.com |
| USB Driver | Required for DSD/Foobar2000 Windows 7/8/8.1/10/11 (Driver Required) |
| 3.5mm Headphone Output (UAC) | |
| Rated Power Output | L+R ≥ 320mW+320mW (32Ω / THD+N < 1%) |
| SNR | 123dB (A-weighting) |
| THD+N | 0.0004% (A-weighting) |
| Dynamic Range | 123dB |
| Noise Floor | ≤3μv (A-weighting) |
| Frequency Response | 20Hz-20kHz (±0.06dB) |
| RCA Output (UAC) | |
| Rated Power Output | ≥2Vrms |
| SNR | 124dB (A-weighting) |
| THD+N | 0.0005% (A-weighting) |
| Dynamic Range | 124dB |
Footstep Detection: Detect and enhance footsteps in real time, helping you track enemy movement with greater precision and react faster in FPS games.
Noise Cancellation: Noise Cancellation reduces background distractions like keyboard clicks and fan noise with up to 40dB deep noise reduction, delivering cleaner voice chat for gaming, streaming, and calls.
Custom Sound Presets: Fine-tune your sound with EQ presets and customizable audio controls, optimized for different game genres and immersive listening across both competitive and casual gameplay.
HiFi-Grade Gaming Audio: Powered by XMOS and TI amplifier chips, C3 delivers clean separation, detailed imaging, and precise directional audio for gaming and music alike.
Powerful Across Platforms: Compatible with PC, PS5, Switch, headsets, and desktop speakers, C3 works as an all-in-one gaming DAC and amplifier for both competitive play and everyday entertainment.
- Fosi Audio C3
- User Manual
- USB-A/C to USB-C Cable
- Y-Splitter Cable
What Is StepSense™ AI Footstep Enhancement?
StepSense™ is Fosi Audio's proprietary AI technology that detects and enhances enemy footsteps (3-9dB) in real time with ultra-low latency (just 10ms), without affecting other sounds such as gunfire or explosions. The AI model is trained on extensive FPS game audio data and runs locally on the C3 hardware — it does not consume any computer resources. We continue to refine the algorithm to improve accuracy and game compatibility.
What Is AI FPS Mode?
AI FPS is an intelligent audio processing algorithm developed by Fosi Audio specifically for FPS games. By training on extensive in-game audio data across multiple titles, the algorithm can identify and dynamically enhance critical sound cues — such as footsteps — in real time, helping you achieve more precise positional awareness even in chaotic gameplay environments. To use this feature, enable AI FPS in the companion app, select the corresponding game sound profile, and launch the game. The indicator LED on the device will illuminate orange when AI FPS is active. Please note: AI FPS is available only in UAC 1.0 mode. When enabled, all other sound modes are automatically disabled. For games that have not received dedicated optimization, enabling AI FPS does not guarantee a noticeable effect.
Best Matches & Operation Guide for C3 Gaming DAC
For the best experience, we recommend using headphones within the 16Ω-300Ω impedance range. For competitive FPS games (PUBG, CS2, Delta Force), use UAC 1.0 mode with the corresponding AI FPS preset. For movies and multichannel content, 7.1 spatial audio delivers an immersive surround experience. For HiFi music listening, switch to UAC 2.0 and use Bypass or PEQ mode. Always ensure your headset uses a 3.5mm connection for full compatibility with the C3's microphone features.
We recommend our IM4 Hi-Fi headphones — perfect for immersive gaming and casual music listening on the go.
Should I turn off in-game spatial audio for Delta Force when using an external DAC?
No, you do not need to disable them. HRTF and multichannel audio do not conflict with the AI algorithm. You can keep them enabled and adjust based on your personal listening preference. For Delta Force, we recommend the settings listed above as a starting point.
