  New Customer | 10% Off w/ code NEWFA10
                - The Best Bluetooth Audio Receivers of 2025
                Shipping Information We offer free worldwide shipping, except for certain regions such as Ukraine and Russia, where our services are currently unavailable.
                Customer Support WhatsApp: +8613716612254
 Mon-Fri: 3:00 AM - 3:00 PM PST
                FAQ’s If you have any questions, please refer here: FAQs
- High Efficiency: A significant upgrade from the BT20A amplifier. There're two plug-ins NE5532 Op-Amps can be replaced by SS3602, MUSES02,  OPA2134PA Op-Amps, etc. To create a different sound quality. SNR≥108dB; THD≤0.005%.
- Output Power: 300Wx2 @4Ω
- Terminating Impedance: 2-8Ω
- Input Mode: Bluetooth + RCA
- THD: ≤0.005%
- SNR: ≥108dB
- Chip Set: TPA3255
- DC Input Range: 24-48V
