Front Side
Back Side
Power Variability
  • Output Power: 300Wx2 @4Ω
  • Input Mode: Bluetooth + RCA
  • THD: ≤0.005%
  • SNR: ≥108dB
  • Chip Set: TPA3255
  • Bluetooth Antenna x 1
100W x2
Bluetooth + RCA
Passive Speakers
≤ 0.04%
≥98dB
TPA3116 x2
24V/4.5A
From $69.99
2.0 CH Amp
Based on 176 reviews
83%
(146)
14%
(24)
Kim Sho
Fun and flexible amp
I bought this amp to pair with a vintage tube preamp that I have and to try it stand alone with the Bluetooth option. Setup was very easy and Bluetooth pairing was flawless. I upgraded to the 48v power supply because one of my pair of speakers are a 4 ohm hard to drive ribbon design. This little amp drives my speakers nicely and sounds good, although, can be alittle bright on the high end. When I connect my tube preamp with the fosi amp, any harsh brightness goes away. Conclusion: Good stereo amplifier for wide-ranging applications and speaker use. I would recommend buying this bt20a pro.
David Shaw
Fosi Audio Products
I purchased BT20A pro and the P4 preamp. I have them powering a pair of Bowers and Wilkins tower speakers and a Jensen EHT 7 sub.
The sound quality is extraordinary and the Fosi products power everything with ease and power to spare. I also have the Bt20 powering my Yamaha speakers around the pool . Fosi audio products are top notch and are extreme value for money. Customer service is remarkable!! Thankyou Fosi.
Troy Marlowe
Works great, like all my other Fosi units!
I needed a Bluetooth unit that had a little more power than my previous one. I also got the upgraded power supply. This new unit works great. It’s for my outside TV and larger poke speakers. Very happy with it my TV remote and DIRECTV TV remote controls the audio which I really like! The blue color is also a conversation starter.
l
laurent chaudru
Étonnant !
Mieux que mon Onkyo , plus finaliste, plus puissant. Un très bon ampli
Lindsay
Amazing sound from this little amp. Very pleased
