Front Side
Back Side
Power Variability
  • Output Power: 300Wx2 @4Ω
  • Input Mode: Bluetooth + RCA
  • THD: ≤0.005%
  • SNR: ≥108dB
  • Chip Set: TPA3255
  • Bluetooth Antenna x 1
100W x2
Bluetooth + RCA
Passive Speakers
≤ 0.04%
≥98dB
TPA3116 x2
24V/4.5A
From $69.99
2.0 CH Amp
Based on 170 reviews
83%
(141)
14%
(23)
Benjamin S
A solid amp choice!
I’ve had for a few weeks now - using to power a pair of Axiom M3 bookshelf speakers. The amp does a good job driving these speakers! Bluetooth function has worked very and no issues so far. I’ve had music playing for multiple hours and the amp seems to dissipate heat very well as it’s never felt hot. Given my experience, with the BT20a pro, I’m looking at getting a pair of their V3 monos to power some towers in my home theatre set up.
Yaroslav Brustonov
Michael Frisco
Love this amp.
Powers my Polk Atrium speakers with no problem. The Bluetooth works great. Love the size and look.
Dorothea Singer
BT20A with 48V power supply is a very good choice
I’m using the BT 20A Pro for amplification, and the Fosi P4 preamplifier, in my multiroom Wi-Fi Streaming scheme which drive some vintage Paradigm Titans. It is a potent combination, they get an A+ grade!
Dan Kniowski
More power
Nice little amp. I bought 32v with BT20A for use with a small 4ohm bookshelf speakers, but they didn’t sound good too much treble very little bass I tried.KLH bookshelf speakers much better ,but they r 8ohm . I’d like to send a 32 V back and buy a 48 V with free shipping also Interested in changing the amp chips and some other products like the turntable pre-amp
