Front Side
Back Side
Power Variability
  • Output Power: 300Wx2 @4Ω
  • Input Mode: Bluetooth + RCA
  • THD: ≤0.005%
  • SNR: ≥108dB
  • Chip Set: TPA3255
  • Bluetooth Antenna x 1
100W x2
Bluetooth + RCA
Passive Speakers
≤ 0.04%
≥98dB
TPA3116 x2
24V/4.5A
From $69.99
2.0 CH Amp
Based on 188 reviews
82%
(154)
14%
(26)
Pere Vilanova
All good
Robert Westbury
Good but...
Needs a remote or at least IR receiver for smart remotes to send volume signals to.
Panapat
BT connection confusion
I was replacing a old BT20A with this new one. It would not connect to the Fosi BT connection on my phone. Turns out the BT connection must be paired to any new BT20A, not a old connection. Not a complaint just a note. Sound is great for my listening preferences.
Ron Risden
Simple, straightforward to use, and great quality
I had some concern over ordering this sight unseen, but it has been a wonderful addition to my passive speakers.
Timm Rye
BT20A
I love the BT20A. It sounds and looks great and is a steal for the price. Fosi Audio knows what they are doing and I will be back to make additional purchases.
