Front Side
Back Side
Power Variability
  • Output Power: 300Wx2 @4Ω
  • Input Mode: Bluetooth + RCA
  • THD: ≤0.005%
  • SNR: ≥108dB
  • Chip Set: TPA3255
  • Bluetooth Antenna x 1
100W x2
Bluetooth + RCA
Passive Speakers
≤ 0.04%
≥98dB
TPA3116 x2
24V/4.5A
From $69.99
2.0 CH Amp
Based on 174 reviews
83%
(145)
13%
(23)
Troy Marlowe
Works great, like all my other Fosi units!
I needed a Bluetooth unit that had a little more power than my previous one. I also got the upgraded power supply. This new unit works great. It’s for my outside TV and larger poke speakers. Very happy with it my TV remote and DIRECTV TV remote controls the audio which I really like! The blue color is also a conversation starter.
l
laurent chaudru
Étonnant !
Mieux que mon Onkyo , plus finaliste, plus puissant. Un très bon ampli
Lindsay
Amazing sound from this little amp. Very pleased
Shizzo Dubs
Solid sound quality and beautiful simplicity.
I bought a Fosi BT20A Pro as a place holder in our dining room while we wait to get an antique Sansui amp restored. I auditioned a Wiim Amp Pro first and didn't appreciate the sound, especially the lack of bass. Even after trying lots of EQ and speaker placement adjustments. The Fosi was suggested to me via an audio forum. Instantly upon hearing the little Fosi, and giving the treble and bass knobs a quick precursory twist, I was immediately much more satisfied w/ the music coming through my Wharfedale Denton 80th's. I quickly returned the Wiim and am really rather impressed w/ how well this tiny little amp delivers. I opted for the 48V GaN power supply and I'm not sorry. I wish it had a higher quality Bluetooth codec like Apt-X HD or LDAC, but I don't think anything else can touch this at this price point. Highly recommended.
Benjamin S
A solid amp choice!
I’ve had for a few weeks now - using to power a pair of Axiom M3 bookshelf speakers. The amp does a good job driving these speakers! Bluetooth function has worked very and no issues so far. I’ve had music playing for multiple hours and the amp seems to dissipate heat very well as it’s never felt hot. Given my experience, with the BT20a pro, I’m looking at getting a pair of their V3 monos to power some towers in my home theatre set up.
