Front Side
Back Side
Power Variability
  • Output Power: 300Wx2 @4Ω
  • Input Mode: Bluetooth + RCA
  • THD: ≤0.005%
  • SNR: ≥108dB
  • Chip Set: TPA3255
  • Bluetooth Antenna x 1
100W x2
Bluetooth + RCA
Passive Speakers
≤ 0.5%
≥98dB
TPA3116 x2
24V/4.5A
From $69.99
2.0 CH Amp
Based on 190 reviews
82%
(155)
14%
(27)
GreatGobster
Amp works perfect, great sound for price!
Hooked these up to a pair of vintage 80s bookshelf speakers, sound is excellent and the Bluetooth pairing is smooth. Really pleased with this purchase.
Kim Lee
Good sound
For most of the music I listen to, the sound is excellent. However, for very high notes, it cracks a bit. I am replacing the op-amp with the Sparko Lab's SS3602.
Warren
So far so good
Only recently received but so far pleased with this unit. Very compact, nice clean design and powers a couple of passive Tannoy shelf speakers effortlessly. On/off switch is a bit unrefined but can live with that.
Pere Vilanova
All good
Robert Westbury
Good but...
Needs a remote or at least IR receiver for smart remotes to send volume signals to.
