The Bluetooth Stereo Amplifier adopts performance 2pcs texas instrument TPA3116D2 amp chip, dual-channel max output power 50W x2 +100W to get clear audio sound, no pop, no audible noise, dead silent when nothing is playing through it;
Speakers full frequency output, By using the custom treble bass knob and adjustable 40-300Hz cutoff frequency for the subwoofer, you'll be able to get the best sound;
Supports wireless playback from Bluetooth devices, Bluetooth 5.0 wireless music streaming technology with external antenna make a transmission distance of more than 15m/49ft;
Full metallic shell to ensure high quality and durable, advanced circuitry design, built-in speakers protection circuit to ensure Hi-Fi clear and clean sound; With unrivaled sound for the customers who pursue HiFi sound;
Upgraded DC power outlet for safe use without sparks, included high quality 24V/4.5A power supply (The plug of the power adapter will match the country of your delivery address) enough to drive most passive speakers and powered/passive subwoofer.
| Model | BT30D |
| Chippest | TPA3116D2 |
| Maxpower Output | 50W*2+100W |
| THD | 0.05%(@1W) |
| SNR | ≥98dB |
| Working Voltage | 12-24V |
| Speakers Frequency Response | 20Hz-20kHz(±3dB)m |
| Bass Cutoff Frequency Range Adjustment | 20-200Hz |
| Impedance | 2-8 Ohms |
| Device Dimension | L118 x W132 x H35 mm/4.72 x 5.2 x 1.38inch |
| Input mode | Bluetooth/RCA |
| Output mode | Passive Speakers + Passive/Active Subwoofer |
| Bluetooth | Bluetooth 5.0, up to 15m/49ft wireless range without hindrance |
| Wireless Range | Up to 15m/49ft |
| Fosi Audio BT30D Amplifier | 1 |
| 24V 4.5A Power Supply | 1 |
| User’s Manual | 1 |
Video
Compare with similar items
