C3 Gaming Sound Card
Your Footstep Radar in Every Fight
Less guessing. Clearer positioning. Faster reactions
StepSense™
Tracks Enemies Beyond Your Vision
Detect & Boost Footsteps (3-9 dB) | 10 ms Ultra-Low Latency ||No Change to Gunfire/Explosions
Trained on extensive FPS audio data, StepSense™ is continuously reffined for higher accuracy and better game compatibility
Experience It Yourself
Born for FPS Games
HEAR FROM GAMERS
Endorsed by renowned gaming creator Joshua Valour, trusted by 180K+ followers
Alt image
Choose the Right Sound Card
Gaming Audio Flagship
with HiFi sound.
uy Now
Hyper Footstep Radar
Born for FPS Games
HEAR FROM GAMERS
with HiFi sound.
uy Now
Flagship Chipset
Reveal Fine Details with Ease
With audiophile-grade components, C3 reveals subtle details in game audio, adding depth and realism without altering the original sound design.
7.1 Spatial Audio
Battle Comes Alive
In games or movies that support multichannel output, such as Delta Force and Forza Horizon 5, enabling 7.1 audio delivers realistic distance cues and deep immersion.
Control Hub
Sound Presets for Immersion
Switch between presets or fine-tune your sound with EQ controls, all through a clean, browser-based interface, no software required.
Rich Connectivity & Controls
General Specs
Chipset
XMOS XU316 + CS43131 + TPA6120*2
Maximum Sampling Rate
UAC 2.0:PCM 32-bit/384kHz; DSD256
UAC 1.0:PCM 16-bit/48kHz
OPT:PCM 24-bit/192kHz
COAX:PCM 24-bit/192kHz
Supported Headphone Impedence
16-300Ω
Coaxial, Optical, USB-C (Power & Data), 3.5mm Microphone
3.5mm Headphone, RCA
Firmware Update
USB-C Online Update
Input Voltage
DC 5V
PEQ Page Link
https://cc.fosiaudio.com
USB Driver
Required for DSD/Foobar2000
Windows 7/8/8.1/10/11 (Driver Required)
Mac OS X 10.6+, Linux (Driverless)
Audio Parameters
3.5mm Headphone Output (UAC)
Rated Power Output
L+R ≥ 320mW+320mW (32Ω / THD+N < 1%)
123dB (A-weighting)
0.0004% (A-weighting)
Dynamic Range
123dB
Noise Floor
≤3μv (A-weighting)
Frequency Response
20Hz-20kHz (±0.06dB)
RCA Output (UAC)
Rated Power Output
≥2Vrms
124dB (A-weighting)
0.0005% (A-weighting)
Dynamic Range
124dB
Noise Floor
≤3μv (A-weighting)
Frequency Response
Flagship Chipset
Flagship Chipset
7.1 Spatial Audio
Battle Comes Alive
Flagship Chipset
Flagship Chipset
Control Hub
Flagship Chipset
General Specs
Chipset
16-300Ω
Firmware Update
USB-C Online Update
Input Voltage
DC 5V
PEQ Page Link
USB Driver
Audio Parameters
Rated Power Output
123dB (A-weighting)
Dynamic Range
123dB
Noise Floor
≤3μv (A-weighting)
Frequency Response
RCA Output (UAC)
Rated Power Output
≥2Vrms
124dB (A-weighting)
Dynamic Range
124dB
Noise Floor
≤3μv (A-weighting)
Frequency Response
Footstep Detection: Detect and enhance footsteps in real time, helping you track enemy movement with greater precision and react faster in FPS games.
Noise CancellationNoise Cancellation reduces background distractions like keyboard clicks and fan noise with up to 40dB deep noise reduction, delivering cleaner voice chat for gaming, streaming, and calls.
Custom Sound Presets: Fine-tune your sound with EQ presets and customizable audio controls, optimized for different game genres and immersive listening across both competitive and casual gameplay.
HiFi-Grade Gaming Audio: Powered by XMOS and TI amplifier chips, C3 delivers clean separation, detailed imaging, and precise directional audio for gaming and music alike.
Powerful Across Platforms: Compatible with PC, PS5, Switch, headsets, and desktop speakers, C3 works as an all-in-one gaming DAC and amplifier for both competitive play and everyday entertainment.
  • Fosi Audio C3
  • USB-A/C to USB-C Cable
  • Y-Splitter Cable
