Fosi Audio DS1 Headphone Amps Tiny Amplifier USB DAC High Resolution Supports 32bit/768kHz and DSD512 Headphone Outputs 3.5mm/4.4mm for Smartphones/Laptop/PC/Players
$79.99 USD
$79.99 USD
$79.99 USD
DS1
Model DS1
Terminating Impedance 16-300Ω
Input Mode USB Type C
SNR ≥120 dB
Sampling Rate 32bit/768kHz
DSD DSD64/128/256/512
DAC Chipset ES9038Q2M
Material Tin Alloy
Device Weight 38g
Fosi Audio DS1 x 1
Type-C to Type-C cable x 1
USB-A to USB-C Converter x 1
User Manual x 1
DownloadDS1 User Manual
Based on 12 reviews
92%
(11)
8%
Reynaldo Ruiz Flores
Windows 11 24H2
Victor Bogaert
Small wonder box
Although it is small, is solid built and improves upon the audio quality a lot. Glad that i bought the device
Vincent Carlino
I enjoy the enhanced sounds from my Klipsch speakers. i haven't been able to discern any difference in sound quality from my Dragonfly
Roman Fedorenko
Best headphone dac
Hello,that is one best headphone dac,I've been using it with my Ikko obsydian H10 oem headphones and a Neutron player mostly listening to flac files,and sound is amazing,dac has separate volume control with lots of output power,tested it just for fun with Macbook pro and IPhone 16 pro Max,everything works flawlessly,if you want to get best music listening experience,this dac is for you.
Sándor László
The best at this price!
There is no rival for the price/value ratio! It is very powerful, especially at 4.4 balanced input, it beats even more expensive DACs, there is simply no rival at this price! I love it, I can only recommend it to everyone! If you are looking for a very good DAC at a good price...you have found it! ☝️
