Fosi Audio Luna3 Turntable
The Luna3 features a high-mass acrylic platter to reduce vibration for smoother playback. A precision tonearm ensures accurate tracking, while the removable headshell allows easy upgrades. Its copper motor with servo control maintains stable speed for natural, detailed sound.
- Speed: 33, 45 (electronic speed change)
- Speed Variation: 33: 0.13% 45: 0.13%
- Wow & Flutter: 33: 0.15% 45: 0.15%
- Platter: 300mm (acrylic)
- SNR: 65dB
Smart Features That Just Make Sense
Smart Practicality
Guided by the principle of “less is more,” Luna3 strips away distractions to deliver only what truly matters: a clean analog signal path, intuitive usability, and a timeless visual presence. Whether you’re a seasoned vinyl enthusiast looking for an upgradeable, customizable system, a HiFi newcomer ready for a serious first turntable, or someone seeking a meaningful, design-forward gift, Luna3 invites you into a slower, more intentional listening experience, one quiet revolution at a time.
SNR: 65dB
Tonearm Length & Material: 8.6in (aluminum)
Tonearm Diameter: 12.2mm
Effective Arm Length: 218.5mm
Overhang: 22mm
Dimensions: 420 × 112 × 330mm (W × H × D)
Weight: 3.5kg
Power Consumption: 5W (Max)
Power Supply: 12VDC / 1500mA
- 45 Adapter ×1
- Dust Cover ×1
- 12V Power Adapter ×1
- Counterweight ×1
- Rubber Belt ×1
- Platter Mat ×1
- Plinth ×1
- User Manual ×1
- Headshell with Stylus ×1
- Acrylic Platter ×1
- Felt Mat ×1
