Fosi Audio MC351 2.1 Channel Integrated Amplifier with DAC, VU Meter and Bluetooth - Fosi Audio
$169.99 USD
$169.99 USD
$169.99 USD
  • All-in-One DAC Amplifier
  • High Power with Great Sound
  • 5 input modes: Bass and Treble Controls
  • Mini VU Meter: Classic Retro Vibe
MODEL:
Input: BT/RCA/OPT/USB/COA; Output: Passive Speakers/Subwoofer/Pre-Out
Amp Chip: TPA3255×2; THD: ≤0.03%; SNR: ≥100dB
Max Output Power: 165W×2+350W@4Ω
Supports Five Digital/Analog Inputs
Equipped with mainstream inputs Bluetooth/RCA/COA/OPT/USB, compatible with various audio devices.
Visual Dial, Pointer Dances to the Music
Real-time signal display helps you adjust the volume to avoid overload and distortion.
Customize Your Unique Sound
With bass & treble knobs featuring central detents for natural sound reproduction.
Dual Amp Chips for High Power Output
100 aluminum alloy cooling fins improve heat dissipation & sustain high-quality sound performance.
Save the hassle of repeatedly plugging and unplugging cables, extending the longevity of devices.
Effortless Low-Latency, HiFi Audio Sound
Smartphone + MC351 (Bluetooth Input) + Passive Speakers
Immerse Yourself in a Movie Night
TV + MC351 (OPT/COA Input) + Passive Speakers + Subwoofer
Upgrade Your Audio Setup
Computer + MC351 (USB Input) + Passive Speakers
Unveil Vintage Charm
Turntable+ MC351 (RCA Input) + Passive Speakers
All-Aluminum Alloy Chassis
With precision CNC machined and finely sandblasted, featuring a minimalist and durable design.
Multiple Outputs
Supports outputs for Passive Speakers, Subwoofer, and a Pre-out, enabling flexible setups for both stereo and 2.1 systems.
Automatic Standby Feature
Automatically enters standby mode after 2 minutes of no signal input, effectively reducing energy consumption and extending device lifespan.
Quick Mode Switching
Easily switch input modes with one click, and settings automatically restore to the previous upon restart, eliminating repetitive adjustments.
Dual 4700μF Capacitors
Features high-quality large-capacity capacitors that enhance sound quality, dynamic range, and stability, extending the amplifier's lifespan.
  • All-in-One DAC Amplifier: The MC351 integrated amp features high-resolution decoding capabilities, supporting Bluetooth, USB, Optical, and Coaxial digital inputs. With its extensive input and output options, you can easily set up a 2.1 home theater or other stereo HiFi audio systems.
  • High Power with Great Sound: Equipped with two high-end Texas Instruments TPA3255 Class-D amplifier chips and a 100-fin heatsink, the MC351 can stably output up to 165W x 2 + 350W power in a 2.1 channel setup. The dual PCBA separated design ensures that the input and output signals do not interfere with each other, providing you with the purest and most impeccable sound quality.
  • User-Friendly Control Design: Supports one-touch switching between 5 input modes and includes bass and treble controls, with central detents for tone defeating, for easy sound customization. It also features an automatic standby function, entering standby mode after 2 minutes of no signal input to effectively reduce power consumption.
  • Vintage Charm: The eye candy round mini VU meter adds a classic retro vibe to your sound system. The needle of the level meter will dance to the music, providing you with both visual and auditory enjoyment. The MC351 is an excellent companion for turntables, allowing you to relive classic tracks.
  • Exquisite Craftsmanship: Featuring an all-aluminum-alloy CNC integrated design and a finely sandblasted metal finish, the MC351 boasts a seamless body with no visible screws, showcasing minimalist aesthetics. The all-metal body ensures durability, and you can enjoy the peace of mind provided by Fosi Audio's 24-month warranty.
  • Output Power:
    165W x 2 + 350W @ 4Ω
  • Terminating Impedance: 4-8Ω
  • Input Mode: Bluetooth 5.3+RCA+COA+OPT+USB
  • Output Mode: SPK OUT+SUB OUT+3.5mm PRE OUT
  • THD: ≤0.03%
  • SNR: ≥100dB
  • Device Dimension: 7.28  x 5.0 x 2.24 inches
  • Sampling Rate: USB24bit/96kHz ; OPT/COA 32bit/192kHz
  • MC351 Power Amplifier x 1
Based on 17 reviews
76%
(13)
12%
12%
Byron
Great
Naman
Beauty & the Beast
A beastly machine in a spectacularly compact size.
Arjun Roy
Good sound, just missing a crossover filter on the speaker output
Good sound, just missing a crossover filter on the speaker output. But otherwise, no concerns.
Antonio Garca
The volume is really low and the UV meter hardly moves.
I have only tried it with the Bluetooth and i only plan to use the bluetooth I made sure the volume on the Bluetooth device was all the way up
Jose Fernandez
Keep up the excellent designs !
Excellent piece of equipment with great performance.
