Key Parameters
Signal-to-Noise Ratio≥103dB;
Noise Floor: 64uV;
Crosstalk: 95dB
Mode Indicator
RCA mode: steady red light;
Bluetooth Connectivity
Bluetooth Range: ≥10m
Bluetooth Version: 5.1
Bluetooth Name: Fosi Audio P3
Bluetooth Reset
  • True Tube Amplification: The preamp circuit elevates the voltage to 54V, ensuring the tubes work to their full potential, delivering a warm and rich experience. The unique preamplification technology delivers pure audio signals, faithfully reproducing crisp high tones, full midrange richness, and deep, rhythmic bass.
  • What You'll Get: Fosi Audio P3 Tube Preamplifier x1, User Manual x1, 5654W Vacuum Tube x2, 12V/1.5A Power Supply x1, a 24-month worry-free warranty and responsive customer service.
  • RMS Power: 250mw @16Ω;150mw @32Ω;32mw @250Ω;20mW @300Ω
  • Noise Floor: 64uV
  • Input Mode: Bluetooth, RCA
  • Output Mode: RCA, 3.5mm Headphone Jack, AUX Out
  • Frequency Range: 20Hz-20kHz(±1dB)
  • Dynamic Range: 104dB
  • THD: ≤0.02%
  • SNR: ≥103dB
  • Crosstalk: 95dB
  • Bluetooth Chip: QCC3031
  • Bluetooth Version: 5.1
  • Bluetooth Range: ≥10m
  • Power Input DC: 12V/1.5A~3A;
  • 5654W Vacuum Tube x 1
  • 12V/1.5A Power Supply x 1
  • User’s Manual x 1
Preamp+Headphone Amp
DC 12V/1.5A
≤0.02%
≥103dB
From $119.99
DAC+Headphone Amp
DC 12V/1.5A
≥103dB
Fosi Audio P4 Mini Preamp with 3 RCA Inputs, EQ/Bypass, Treble & Bass Tone Control with Remote Control - Fosi Audio
From $99.99
Preamp
DC 12V/1.5A
RCA x3
RCA, Pre-Out
≤ 0.003%
From $179.99
DAC Preamp
DC 12V/1.5A
XLR, RCA
<0.00008%
≥126dB
Fosi Audio SK01 Headphone Amplifier & Preamplifier - Fosi Audio
Headphone Amp+Preamp
3.5mm Line In
≤ 0.001%
