  • Easy to set up, no special software, app, or driver to install, a true plug-and-play digital audio adapter.
  • With USB, optical and coaxial S/PDIF inputs can fit with most home audio systems, and RCA output can be connected to an amplifier or powered speakers on your desktop;
    Built-in Hi-Fi headphone amp chip can drive most 16ohm to 200ohm headphones.
  • 160mW RMS(32 ohms, 20 Hz - 20 kHz, 0.01% THD), with bass and treble control, can be used as preamp or volume controller for your PC/MAC/Computer.
  • Mini Compact D/A converter, stream bit-perfect 24bit/192KHz HD with low jitter, with output, protect the circuit, safe for your expensive audio system.
Model Q4
PC-USB supports input sampling rate 24Bit/96kHz
High and low sound adjustment range ±6dB
Fiber/coaxial support input sampling rate 24Bit/192kHz
Frequency response 20Hz-20kHz (±3dB)
PC-USB support operating system XP/W7/W8/W10/MAC/Linux
Distortion 0.01%
SNR ≥105dB
Amp output maximum power 100mW 32Ω load
Headphone matching impedance 16Ω-200Ω
Working voltage DC5V
RCA output level 2.3V
Size (L*W*H) 73.5*98*33MM (without knobs and terminals)
Package Include
Fosi Audio DAC-Q4 x 1
5V USB Power Supply Cable x 1
PC-USB Cable x 1
Optical Cable x 1
Compare with similar items
Q5 Mini Headphone Amplifier
Q6 USB HiFi DAC Headphone Amplifier
Q7 Bluetooth 5.0 Hi-Fi Amp
