$99.99 USD
$99.99 USD
$99.99 USD
SK02
SK02 headphone amplifier
Multifunctional Knob for Easier Control
3.5mm Single-End and 4.4mm Balanced
SABRE ES9038Q2M DAC & SGM8262 Op-Amps
Crafted for AudiophilesSupports High-Res PCM384kHz & DSD256
Gain and Input
Model SK02
Input USB/OPT
Output 3.5mm Headphone,4.4mm Headphone,3.5MM line out/OPT
Amp output maximum power 3.5MM:
High Gain: 280mW@32Ω, 130mW@64Ω, 40mW@250Ω, 30mW@300Ω
Low Gain: 90mW@32Ω, 50mW@64Ω, 15mW@250Ω, 10mW@300Ω
4.4MM:
High Gain: 1100mW@32Ω, 550mW@64Ω, 150mW@250Ω, 120mW@300Ω
Low Gain: 350mW@32Ω, 180mW@64Ω, 50mW@250Ω, 40mW@300Ω
Frequency Range 20Hz-20kHz (±0.02dB)
THD ≤0.001% @ 1kHz
SNR 3.5mm Headphone:
Low Gain:116dB
High Gain:120dB
4.4mm Headphone:
Low Gain:110dB
High Gain:115dB
PC-USB Sampling Rate 32Bit/384KHz DSD256
OPT Sampling Rate 24Bit/192KHz
DAC Chip ES9038Q2M
Device Dimension 4.76*2*1.69inch (121*51*43mm)
Net Weight 0.84lb/380g
Power Supply 5V, USB Type-C
Item Quantity Fosi Audio Sk02 Headphone Amp x 1,
2-in-1 USB-A/C to C Cable x 1,
SK02 User Manual
SK02 Windows 7 Drivers
Based on 25 reviews
84%
(21)
8%
4%
4%
SeatedConnector
Buyer beware
Unfortunately, the only was for a PC to control the volume is through optical hookups. If you use USB-C, only the knob on the device will work to control the volume.
Anonymous
These devices deliver excellent performance and are a joy to use
I’ve been very pleased with the Fosi Audio SK02 + SK01 Desktop DAC/Headphone Amp overall. The compact form factor makes these units easily portable, and the equalizers perform remarkably well, offering precise audio adjustments.
My only minor criticism is the slight noise that occurs when turning the volume knob—it’s not a major issue, but noticeable enough. I would also recommend adding a bit of texturing or ridging to the volume and EQ knobs themselves, as they can be somewhat slippery to grip. This small tweak would greatly improve the comfort and precision of fine-tuning the settings. Otherwise, these devices deliver excellent performance and are a joy to use.
Anh Hiếu Nguyễn
Tuyệt vời ông Mặt Trời.
Tôi không ngờ giá trị của sản phẩm lại cao hơn nhiều so với giá thành, thật không ngờ. Tôi sẽ tiếp tục ủng hộ. 👍👍
Wisam Z
Amazing dac amp
Used with Hifiman Sundara and the sound is SO amazing clear big sound stage but lacks sub bass and fixed with equalizer apo and now every thing rocks.
Make sure to use balanced cable with sundara cuz the cans will vibrate your brain !
Dmitry Perevezyonov
Nice DAC!
Quite powerful and superb resolution!
