Fosi Audio T20X Bluetooth Tube Amplifier Headphone
2-in-1: Hifi Music Tube Bluetooth 5.0 Home Audio Receiver 2 Channel Amplifier and Headphone Amp. T20X can drive most home passive/desktop speakers and 3.5MM headphones. Achieve Hifi music quality.
Bluetooth 5.0: Enjoy superior wireless audio experiences with Bluetooth 5.0 core. Faster transmission and more stable connection extended long range up to 50ft/15m. Wirelessly stream audio anywhere you want.
Vacuum Tubes: T20X is equipped with JAN 5654W Vacuum Tubes to get more warm sound. Applicable vacuum tubes model: 6K4/6J1/6A2/6J4/GE5654/6AK5/66*In vacuum tubes, etc. You can replace the vacuum tubes to DIY your stereo system. Different tube with different sound.
Product Parameters: MAX Power Output: 100W x2@4Ω, Terminating Impedance: 4-8Ω, THD: ≤0.05%, SNR: ≥ 105dB, Amplifier Chip: TPA3221, Frequency Range: 20Hz-20kHz(±1dB).
What you Get: T20X amplifier x1, Bluetooth antenna x1, 5654W Vacuum tubes x2, User Manual x1, 24V/4.5A Power Adapter x1, AC Cord x1, 24-month worry-free warranty, and friendly customer service.
| Model | T20X |
| Chip Set | TPA3221 |
| Output Power | 100W x2@4Ω |
| Terminating Impedance | 2Ω-8Ω |
| Input Mode | Bluetooth + RCA |
| Output Mode | Passive Speakers + Headphone |
| THD | ≤ 0.05% |
| SNR | ≥ 105dB |
| Bluetooth Transmission Distance | Up to 28 Ft(10m) |
| Bluetooth Name | Fosi Audio T20X |
| Device Dimension | 5.40 x 4.80 x 1.35 inches |
| Device Weight | 479.8g±10g |
| DC Input Range | 19-30V |
| Power Supply | 24V 4.5A |
| Fosi Audio T20X Amplifier | x 1 |
| Bluetooth Antenna | x 1 |
| Vaccum Tubes | x 2 |
| 24V 4.5A Power Adapter | x 1 |
| User’s Manual | x 1 |
Compare with similar items
