Product Highlights
Amplifier Chip
Power Output
THD
Product Highlights
Amplifier Chip
Power Output
THD
Refresh Season | 15% Off w/ code SFA15
- TPA3255 Chip, 88dB SINAD
- Full-Body Heatsink Cooling
- Pre-out with Volume Control
Born for HiFi Enthusiasts
- Max Power Output: 300Wx2@4Ω
- SINAD: 88dB | SNR: ≥110dB
- Chip Set: TI TPA3255
- Output Power: 300Wx2 @4Ω
- Terminating Impedance: 2-8Ω
- Input Mode: RCA
- SINAD: 88dB
- THD: 0.003%
- SNR: ≥110dB
- DC Input Range: 24-48V
- V3 Power Amplifier x 1
- User’s Manual x 1
