Fosi Audio XLR Cable
- Durable build with braided and shielded materials
- Zinc alloy connectors resist wear and corrosion
- Balanced design reduces noise and signal loss
- Works with amps, DACs, and mixers
- Short length keeps setups neat and tidy
- Connector Material: Zinc alloy with chrome plating
- Compatible with: ZA3, ZD3
- Not compatible with: AES/EBU connectors
- Premium Construction: Made with nylon braiding, PVC coating, copper foil shielding, anti-pull threads, and oxygen-free copper braiding shielding for superior durability and performance.
- High-Quality Connectors: Features zinc alloy connectors with chrome plating, ensuring excellent conductivity and corrosion resistance for long-lasting use.
- Balanced Audio Transmission: Designed for balanced audio signal transfer, it effectively reduces noise and interference, delivering high-fidelity sound over long distances.
- Versatile Compatibility: Compatible with ZA3 stereo amplifier and ZD3 DAC Preamp, good for professional audio setups like microphones, mixers, and audio interfaces.
- Compact and Space-Saving: The 0.3M (1ft) length is perfect for tight spaces, ensuring a neat and organized setup without excess cable clutter. Ideal for desktop microphones and compact audio interfaces.
- XLR Cable*2
