  • SNR≥126dB; THD+N<0.00008%
Swappable Op-Amp Design
Bypass Mode
Trigger In/Out
Perfect Match to ZA3 Amp
  • Maximum Sampling Rate:
    USB: PCM 32bit/768kHz; DSD512
    OPT/COAX: PCM 24bit/192kHz
    Bluetooth: PCM 24bit/48kHz
  • Output Level:
    XLR: 5Vrms RCA: 2.5Vrms
  • Output Mode: XLR, RCA
  • SINAD: 126dB
  • THD: ≥120dB
  • THD+N: <0.00008%
  • Dynamic Range: ≥123dB
  • Noise Floor: ≤2μV
  • Bluetooth Version: 5.0
  • Power Supply: DC 12V 1.5A
  • DAC ZD3 *1
  • 12V Power Adapter *1
  • Infrared Remote Control *1
  • USB-A to USB-B Cable *1
  • 3.5mm Trigger Cable *1
  • USER MANUAL *1
From $179.99
DAC Preamp
XLR, RCA
<0.00008%
≥126dB
Chipset
DC 12V/1.5A
From $119.99
DAC+Headphone Amp
250mw@32Ω
RCA, 3.5mm Headphone Jack
>103dB
Chipset
16-300Ω
DC 12V/1.5A
From $189.99
DAC+Headphone Amp
2x 2.1W@32Ω
≤ 0.0002%
≥121dB
Chipset
16-300Ω
DC 12V/2A
From $99.99
DAC+Headphone Amp
1.1W@32Ω
USB-C, Optical
≤0.001%
≥120dB
Chipset
16-300Ω
How to replace the op-amps?
Based on 166 reviews
81%
(135)
13%
(21)
4%
(6)
v
vlad335
I am completely surprised!
Just got the ZD3 for a secondary system. Arrived today and I put it in my PC setup which uses a Denafrips Ares II as the DAC. Granted, the ZD3 isnt as good as the Ares, but it was surprisingly close! We are talking about a DAC that is nearly 10 times the price!
I ordered a pair of Sparkos ss3602 opamps and will try it in this setup again using the same test track.
DAVID DELVALLE
Satisfaction guaranteed
Well... delivery time was on point. It arrived at the stipulated time. The product is excellent and surpassed my expectations. It is a privilege to be able to hear and this product has enhanced the experience and I recommend it to everyone. Thank you for the service rendered.
Jeffrey Hill
I love this unit
Inserting the ZD3 between my tv and my powered monitor speakers took every aspect of convenience and sound quality to levels that I did not expect out of such an affordable unit. I may upgrade the opamp at some point, but I am in no hurry. It sounds absolutely superb as is.Fit and finish is just as immaculate as the sound quality.
Jeff M
Only three star rating because of the XLR cables. The DAC is a good buy
At the time I was making a purchase of the ZD3 DAC I asked a question about the balanced XLR cables that FOSI Audio had for sale I wanted to know if this was one cable for the price or if it was a pair of cables so I clicked the need help button on the web site and asked the question is this a single cable or is it a pair of cables? The answer I got was it is a single cable. I asked a second time because it showed two cables in the web page picture and the web page help said is was only one cable so I made an order of two for the cables and it ended up that I got two pair of cables I didn’t like that so I will give only a three star rating. On the other hand I do like the DAC it is a good buy.
Lance Johnston
Zd3 vs jbl
I've been connecting to my older JBL home theater with my phone and thinking it sounded good enough. I upgraded my speakers and wanted newer tech to drive them. I compared the sound quality between the onboard DAC installed in the JBL and the Fosi ZD3. The fosi was a big improvement. I could hear the actual cymbal strikes, not just crashes distorting into the next crash. Deeper base too.
