Product Highlights
DAC
OLED Display
In/Out
DSD512
Product Highlights
DAC
OLED Display
In/Out
DSD512
- High-Performance ES9039Q2M Chip
- XLR Output / Trigger In/Out
- Perfect Match to ZA3 Amp
- Input: USB, HDMI ARC, Optical, Coaxial, Bluetooth; Output: XLR,RCA
- SNR≥126dB; THD+N<0.00008%
- Bluetooth Codecs: SBC, AAC, aptX, aptX HD
- Chip Set: XMOS XU316 + ESS 9039Q2M + QCC3031 + LME49720
- Maximum Sampling Rate:
USB: PCM 32bit/768kHz; DSD512
OPT/COAX: PCM 24bit/192kHz
Bluetooth: PCM 24bit/48kHz - Output Level:
XLR: 5Vrms RCA: 2.5Vrms - Input Mode:USB, HDMI (ARC), Coaxial, Optical, Bluetooth
- Output Mode: XLR, RCA
- SINAD: 126dB
- THD: ≥120dB
- THD+N: <0.00008%
- Dynamic Range: ≥123dB
- Noise Floor: ≤2μV
- Bluetooth Version: 5.0
- Bluetooth Connection Distance: ≥13m
- Bluetooth Transmission Audio Format: aptX HD, aptX, AAC, SBC
- Power Supply: DC 12V 1.5A
- USB Compatible Devices: Windows 7, 8, 8.1, 10, 11 (Some require drivers; please refer to the user manual)Mac OS X, Linux (No driver required)
- DAC ZD3 *1
- 12V Power Adapter *1
- Infrared Remote Control *1
- USB-A to USB-B Cable *1
- 3.5mm Trigger Cable *1
- USER MANUAL *1
